Question about Health & Beauty
I have a weighmax W-HD200 Diamond Series Scale. The problem is it isn't reading a weight. It is brand new and when I put the batteries in the display comes on (all 888888) and then zeros out. But it won't register anything but it will read o-ld when pressed harder.
SOURCE: Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Posted on Nov 20, 2008
r321567499
  • 74 Answers
SOURCE: Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
fitnessbalan
  • 59 Answers
SOURCE: I have a Tanita scale. It will not register weight.
Sounds like somehow it was calibrated to your weight as zero instead of 0. I would contact manufacturer here is the contact info.
http://www.tanita.com/en/contact-us/
Posted on Mar 16, 2009
fitnessbalan
  • 59 Answers
SOURCE: My weight watchers scale reads ron when you tap it.
I would contact customer support here is the webpage on the site.
http://www.conair.com/-cn-18.html
Posted on Mar 21, 2009
SOURCE: E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Posted on Jul 28, 2010
Digital scales weigh half of accurate weight
Recalibrate. If that does not take, then there is an issue with the scale. Try installing a new battery since a bad or weak one often results in erroneous readings.
Jun 28, 2017 | Health & Beauty
Why is The scale is not measuring anything?
Did you remove the transport protection?
Perhaps you should remove the battery and reinsert it again?
Jun 27, 2014 | Taylor 3831bl Digital Scale 6.6...
I just received product JB5413. Batteries were just purchased today. The remote is working fine, but it will not weigh. The instruction manual is minimal. I need help getting this to work.
If it's any consolation my Jobar/Ideaworks JB5413 scale has the a similar problem: will not weigh, yet the remote control functions okay. About one attempt out of ten will cause a weight display, though. Can't figure out why scale works occasionally, vs. never works. Batteries are new, and the battery compartments are free of corrosion.
Jan 15, 2011 | Jobar International Ideaworks Remote Read...
Have a WeighMax postal scale..how to I cange from kg to pounds?
I had mine set to ozs for over a year and then it changed to kg. Couldn't reset it by hitting the button, so I removed the battery and then put it back in. It reset it to ozs.
Jan 15, 2011 | Precision Camera Weighmax Body Fat, Body...
My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
May 14, 2010 | Salter 2001 electronic kitchen scale
Just purchased the Ideaworks Large Capacity Bath Scale with infrared receiver and I can't get it to display the weight. The receiver seems to be working (can set clock, lbs, etc. . . ) but nothing happens...
If it's any consolation, my Jobar/Ideaworks JB5413 has developed the identical symptoms, although occasionally it will start working briefly. Batteries are new, and no corrosion in the battery compartments. I am thinking about just junking this nicely styled scale; what a shame.
Apr 22, 2010 | Jobar International Ideaworks Remote Read...
Need to know how to adjust the weight
Try putting brand new batteries in and letting the scale zero out and then shut off on its own. Sometimes it's "zero" is misrepresented by an old set of batteries. Also, do any kids live in the house that might have jumped on it? If so, it would be wise to buy a new one as the sensitivity will be ruined for life.
May 08, 2009 | Elite Home Electronic Personal Bathroom...
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 | Irons
Health & Beauty Logo
130 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
