Question about IBM ThinkPad T43 Notebook
Trying to upgrade H/D on IBM T43 laptop, get 2010 error on
I keep getting a 2010 error on boot up. I tried to perform the harddrive update with IBMs FW updater but it keeps telling me that there is no FW to update. The hard drive is a Hitachi model # HTS541616J9AT00 which is on the IBMs list of H/Ds that will work with this laptop (IBM T43) after the FW update is performed.
  • Anonymous Mar 21, 2009
    I have a ibm t43 with a hd 5k160 120GB. Error 2010 shown during bootup.
  • 60 Answers
Error code 2010 is definitely hard drive problem.
Did you get the firmware from the site below?
Link to hardware maintenance manual for reference:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t2393.pdf
Here's the fix straight from the maintenance manual:
If in the primary bay the customer is using a non-IBM or non-Lenovo hard disk drive (HDD), or an old generation IBM HDD which is not supported by this system, with the risk in mind, the customer can still use it by pressing ESC. If in the primary drive bay the customer is using a supported IBM/Lenovo HDD with an old firmware, the customer needs to update its firmware to the latest. The latest version is available at http://www.lenovo.com/think/ support
Posted on Apr 07, 2009
Window7 fails to update thinkpad t43. other devices update
you need to download the driver manually from the ibm website
May 21, 2012 | IBM ThinkPad T43 Notebook
It does not boot anyway on hdd or cd, i have ibm screen one time out of ten ; IBM T43 PENTIUM M 1.86GHZ/RAM 1Go/HDD 40.Go BIOS already updated with latest version from lenovo
restart the system and continue to press F2 ,so tht u can enter into the BIOS settings,change the boot option to cd/dvd...if still the problem persists clean your dvd case once or continue with another cd/dvd...
May 06, 2010 | IBM ThinkPad T43 Notebook
Ibm t-43 laptop cannot find hard drive even though there is one and hard drive was reimaged successfully. rebooted laptop and keep getting error message
Make sure harddrive is set for CS check jumper on drive, Make sure no pins are bent on hard drive, Stop the computer at the bios setup and check the bios is set right..If all this fails you could have an motherboard issue, since you have mention that "the drive has been reimaged"
Feb 24, 2010 | Lenovo IBM ThinkPad T43 Notebook PC -...
T43 kill switch and reload windows info please my computer has been infected with a worm and many trojans it will not llow me to go into control pnel or get to dos to kill it and reinsert the disk to...
At this point i would call your Current Operating system dead. If you can boot into XP and move and documents or pictures you want to keep onto a USB drive. Once this is done, I can not guarintee the files will not be infected but, if you MUST keep some of your files, it is worth a try.
From power off, Boot your T43, pressing the Blue IBM ACCESS button when the screen first turns on. just keep pressing it until the screen turns to Loading IBM Access and recovery. This is a hidden partition on your hard drive, (safe from that pesky worm and trojans) which contains the backup files needed to completely restore your comp to factory default.
In here you will want to select continue to get the initial screen to go away, navigate over to the left hand bar, and one of the options will allow you to completely restore to factory settings, select it, and run through the pop-ups. once you have done this it will take about 40 minutes to run, and boot up with a CLEAN and fresh version of XP, run Windows update and start installing your programs you lost. Best of Luck.
Nov 16, 2009 | IBM ThinkPad T43 Notebook
IBM t43 laptop wont power up
did you try to check if the power supply is working properly coz if no lights at all it means no power is coming.
Sep 16, 2009 | IBM ThinkPad T42p Notebook
T43 upgrading bios
The bios needs an operating system to work. That's why it's called an operating system. DOS will even work but, you must have something.
Jul 31, 2009 | IBM ThinkPad T43 Notebook
BIOS self-set Password after upgrade/HD Install
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
try this if you can do  but i am not sure.  i am good on electronic things but its hard to do that. its only way.
May 28, 2009 | IBM ThinkPad T43 Notebook
Ibm t43, xp pro won't recognize my WD my book
please write down the error and contact me now
anaesarora online
Feb 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Hard drive failure on IBM T43
I have a ThinkPad T43,
Now it's hard drive is broken so when i change the new hard drive Hitachi 160GB it display the message as below.
Could you help me to terminate this error message.
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
I try to update firmware of the harddrive but still appear the message the same.
Apr 23, 2008 | IBM ThinkPad T43 Notebook
Disk read error, please help
If it was dropped on the floor, more than likely, that spinning hard drive is damaged and has failed. The computer caqnnot load the operating system. You will definitely have to replace the hard drive, and hope the data is recoverable. Keep in the mind, the hard drive is constantly spinning, and any shock at 30G's or more can be fatal.
Picture moving a turntable while its playing, accept, instead of spinning at 33.3 rpm's its spinning at 5400 rpms, faster than most car engines......
Good luck.
Dec 16, 2007 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
2,315 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
