Question about Kitchen Ranges
Frigidaire stove new changed to propane gas top works fine oven flame to hi smell gas to rich open air valve turned down orfice changed port in regulator
  • 583 Answers
Explain your problem in more detail clearly
Posted on Mar 13, 2009
I have a frigidaire gallery propane stove. I just bought it a couple weeks ago. We converted in from natural gas to propane, the top works great but the ovens gives off a terrible smell whenever we use it....
THAT IS VERY COMMON,YOU HAVE TO EITHER CHANGE THE ORFFICE ON THE OVEN AS WELL OR ADJUSTED,TURN IT DOWN CLOCK WISE TO REDUCE THE GAS FLOW,THEN OPEN THE AIR FLOW WINDOW ALL THE WAY,ADJUST 1/2 A TURN AT THE TIME .....AND PRESTO
Apr 21, 2013 | Kitchen Ranges
The wall behind my propane oven is black, why?
possibly the air shutters were not adjusted when new for propane use,most units come set-up to burl natural gas but need conversion to burn l.p. gas by changing the orfices on the top burners,then turning the orfice spuds down on the bake and broil orfices as to control the flow of a heavier gas and also opening the air shutters on these venturi gas feed tubes next to these orfices
Dec 12, 2012 | Kenmore Ovens
Broiler flame on hotpoint stove needs adjustment
as in height of flame? if its too large a flame and you have switched from natural gas to propane gas you must turn the orfice spud down onto the orfice face to adjust it,just land it lightly,do not turn it down overly tight
May 05, 2012 | Hotpoint Ovens
Purchased a used gas oven yesterday. The top burners are working fine, but the oven is sooting up. We live in the country and use propane, but did not receive any additional orfice or instructions. In the...
We need a model number to be specific.
Check the gas regulator and make sure the pressure cap has been set for propane.Most of them are turned over to put more pressure inside the valve.
If so. Check the air shutter on the bake gas tube and adjust for the best color flame.
Also tighten the bake burner orifice with a 1/2 inch wrench.
Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Gas oven gas not shutting off
sounds like you got some debri in the safty valve, teflon tape or pipe dope. they don't come apart so you will probly have to replace it. sorry! disconect lines and blow out good befor replacing it so it don't happen to the new one
Dec 25, 2009 | Ovens
We have a gas whirlpol that was converted to
on the gas valve there is a orfice a pin hole you can ajust the size of the orfice by tighting the ajustment a little a 1/4 turn . it is on the valve where the gas gos out to the bunner usualy a 1/2 in open wrench fits on it its made of brass you have to open the top to see it there is also a air ajustment where the bunner fits over the gas valve orfice if the flame is red open it more if its to hot close the air a little make the flame red then turn the gas down tell its blue agin
Oct 20, 2009 | Whirlpool Ovens
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
Change over to LP on whirlpool oven
All ovens come from the factory set up for natural gas. To convert to liquip propane you must change the orifices. Once you have the proper orifices, you will be able to make the adjustment you desire. You can contact your lp supplier and have them send their techie out as they do this as a free service.
Apr 07, 2009 | Kitchen Ranges
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
