Vesta 7200 HD Freeview Satelltie Box
I have just blown up my Satellite Freeview box I had plugged in my 1TB hard drive and it wouldn't switch on so I switched off and back on at the power socket. The display started flashing so switched off and on again - now it's DEAD ,
SOURCE: sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
DO NOT PRESS OK WHEN ASKED TO UPDATE SET TOP BOX.
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
Posted on Jul 25, 2008
Crankstart
  • 696 Answers
SOURCE: LaCie Big Disk Extreme 1TB Hard Drive - continuous beep, no power
Hi, Lacie isn't very forthcoming with beep codes but it definitely means one of the two. You can try moving the hard drive into a new enclosure, if it works it was the enclosure, if not the HDD. Hate to say it but warranty on these drives is a moot point the moment unique data is stored on them as you can't even diagnose the problem properly without voiding it and no drive manufacturer will waranty data. If you have no unique data and it's under warranty, send it back. If you have unique data on it that you value, take it to a local computer store and have them move the drive to a new external enclosure and test it. If it works, you're done. If it doesn't, you've confirmed that the HDD is faulty and you will need the help of a data recovery Pro. If the latter is the case, reply by commenting here with your location (country, state city) and I'll recommend a closeby facility for you. Chris
Posted on Jun 05, 2009
SOURCE: Computer freezes on start-up when western digital
This is a known problem with these drives. Disabling USB legacy support in your Bios should solve the problem., it did in my case but at the expense of not being able to boot from a USB device. Definitley a problem with their enclosure or drive.
Ken D
Posted on Aug 13, 2009
acsess
  • 40 Answers
SOURCE: Lacie HD power light flashing yellow and orange
Hi. Sometimes, there are compatibility issues on external drives. Most recent computers will read them while others may not. Either the external casing or the cable is causing this.
Posted on Aug 28, 2009
parrotheadpc
  • 2600 Answers
SOURCE: maxtor 1TB hard disk in the sky HD box failed
I would like to try something here. I would like you to hook the hard drive up to your computer either through the enclosure or better if you have a usb adapter that simply slips onto the sata connector. Once this is done listen for the tone of the computer recognizing the device. It doesn't necessarily have to be recognized as a hard drive. Now, open the control panel and open administrator tools. Open computer management and on the left pane near the bottom click disc management. All of the discs currently hooked to the computer will show is the right pane whether they are active or not. If the disc shows here than it is alive and can worked with. Right click on the disc in question and see if it gives you the option to "Initialize". Some of these enclosures that have their own firmware will sometimes de-initialize a hard drive that has been previously activated. If this is the case, then you can "initialize this disc once more and partition it for use. You will lose your data but the drive will be useful once more.
Posted on Sep 06, 2009
I have a vesta 6300 hd territorial freeview box and it wont come off the menu/settings screen. How do i get ot back to normal? My kids touched the remote and now it wont work. Im located in NZ
I am wondering if the remote still works and still works on all buttons?
Even if the exit button won't work, maybe the box needs to be scrolled through the menus and ok pressed in order to satisfy it.
Maybe disconnecting it from the mains for a while will prompt it to do something. That is what I have to do when my box freezes.
Apr 12, 2016 | Televison & Video
Lacie Case Only lighting up when HD is disconnected
I had the same problem with a 1TB hard drive. The fault was caused by the casing being knocked from the computer and falling onto the desk. If the hard drive hadn't been powered up it would have been ok...
I removed the hard drive from the casing and fitted it into my computer as a slave drive, hoping to access all the music and movies stored in it. No go .. But, it's worth you fitting your hard drive as a slave and trying the same. It's worth a shot.
I took the hard drive to a computer market here in China, where I work. These guys take hard drives apart to fix them, if possible. They couldn't fix my hard drive as it had been powered on when it fell ..
However, I bought a new desktop hard drive and they were able to transfer 95% of all things from the old hard drive to the new one. The cost of transferring from the old hard drive to the new hard drive was the same as the price of the new hard drive. That specialist service doesn't come cheap ... but it can be done. I paid simply because I didn't want to lose what had taken more than a year to download.
Try fitting your hard drive as a slave to see if you can access the information on it. If not, a new hard drive and the cost of transferring your music from your old hard drive may be the only course of action left open to you
Jun 05, 2013 | LaCie Big Disk External USB 2.0 1TB Hard...
How to record to my Sony SLV830 VCR from Sony Bravia 32" after digital switchover
You can't really record from the TV while watching something else. The only way to do that is to have two tuners. What you would need to do is get another converter box and connect that to the VCR, via the second VCR socket. But as you have a Satellite box, you will need to find a scart switching box like the one shown below (try Amazon for them).
This will allow you to connect all your items to the one TV.
Mar 18, 2017 | Sony Bravia S-series Kdl-32s3000 32-inch...
I have a 4 channel Sunluxy H.264 Network DVR, I have fitted a 300gb HDD but although the system is working and I get the 4 cameras on screen the message I keep getting on boot up is HDD not found
Guys this one stumped me for some time, here is my solution that worked like a dream
1. plug the hard drive you are using into a pc and check the hard drive is recognise and works.
2. Delete all partitions
3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
MANUFACTURER MODEL CAPACITY ROTATION
ST3320613AS 320GB 7200 rpm
ST33500320AS 500GB 7200 rpm
ST3750330AS 750GB 7200 rpm
Seagate
ST31000340AS 1000GB 7200 rpm
WD3200AAKS 320GB 7200 rpm
WD5000AACS 500GB 7200 rpm
WD6400AAKS 640GB 7200 rpm
WD7500AAKS 750GB 7200 rpm
WD10EADS 1TB 7200 rpm
WD15EADS 1.5TB 7200 rpm
WD
WD20EADS 2TB 7200 rpm
Maxtor STM3500320AS 500GB 7200 rpm
STM3750330AS 750GB 7200 rpm
HITACHI HDT725032VLA360 320GB 7200 rpm
HDS721010KLA330 1000GB 7200 rpm
FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
Cheers.
Jan 11, 2013 | Home Security
Buffalo external 1tb won't power up
Return the hard drive to the place of purchase, this is a manufacture defect.
May 12, 2012 | Buffalo Technology Buffalo DriveStation...
I have an LCD HDTV BLA. I have Freeview and
Hi.
If you are using an external freeview box you need an HD box (See available products).
If you have an LCD TV with built-in HD tuner (TV will say HD Ready and will have internal tuner), then you can use the TV internal tuner.
The best way to get HD is via satellite. Althought HD Freeview is theoretically available since end 2009 I have not been able to receive any HD channel using Freeview tuner, and I live in a London area where HD FV is supposed to be available since 2010.
Even with Free Sat the choice is poor. You get steadily only BBC HD, where at most you can watch some documentary or drama series (it is a kind of sample channel). ITV HD, BBC1 HD and the rest frequencies on Astra change Sat quite often. I am a TV technician and the sat tuning job is not difficult to me but retuning every month was still an awful waste of time.At the end I gave up and I only watch HD through Sky.
At the end of the day the only efficient way to receive HD TV is still through Virgin or Sky.
Regards.
Ginko
Sep 01, 2011 | Samsung Televison & Video
Is there any way to connect an antenna or to make this freeview compatible in the uk.
This is a monitor and has no tuner capability. You would need to use one of the inputs, probably the HDMI, to connect a HD freeview box or HD satellite box.
Mar 08, 2011 | LG W2361V-PF 23 in. Widescreen LCD Monitor
I have a freeview build into my tv which is Panasonic plasms tv Model no. TH-46PZ8BA and wish to know how I can receive HD channels BBC or ITV. Please advice and help.
HD Ready just means the tv can display HD images from an HD source.
The built-in Freeview box on your tv is not Freeview HD compatible so you'll either have to buy a separate external Freeview HD box or subscribe to an HD satellite or cable service.
In any case, most built in Freeview receivers are of barely adequate picture and reception quality. An external box is usually far better in both respects.
May 29, 2010 | Televison & Video
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
