Hi i have just got the bauer 47inch tv and i cart get the sky + code anywere for the remote can u help me
SOURCE: sky+remote code for my lg tv
hi.ive got a rev 8 sky plus remote and a LG 42PC56 42INCH TV and the code is 0206.hope this helps some people
Posted on Jul 29, 2008
SOURCE: Sky remote codes
0065
Posted on Aug 27, 2008
  • 273 Answers
SOURCE: technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Posted on Jun 03, 2009
SOURCE: i have a 32inch mirai tv but my sky remote control
Try using 0000 code
Posted on Jul 21, 2009
the code for the new sky hd remote for my technika 42 -502 plasma tv that controls the volume is 0206 works ok now
Posted on Feb 15, 2010
Sky remote code for my bush lc-46gl12f tv I've tryd all of sky's codes and no luck please help
try this...press TV on your sky remote now hold select and red button until it flashes tvice,now enter this code....1430...after u enter that code it should blink twice again,now press standby,if it turns your TV off,press select to save these settings, it will also control your TV volume...Let me know if this helps
Feb 09, 2013 | Televison & Video
We have a lg 47inch tv with led/lcd hd. do you have the codes to programe my sky+HD remote to use on the tv?
On your sky remote select interactive button, go too customer services and select option 5 , setting up sky remote, you should be able to find lg codes to try there. If not then try the internet for codes. You may have to wait though I didnt get my code for 6 months after getting new tv, but dont give up.
pete
Nov 12, 2010 | LG Televison & Video
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
Sky remote code unavailable? Is it possible to use sky remote for hanspree tv?
Hi you can get your sky remote code by pressing interactive then going to sky customer service (Option 4) then choosing your code it will remind you what it is :) I hope this helps and also im pretty sure you can use your sky remote for a hanspree tv they work with almost every tv
Jul 18, 2010 | Televison & Video
Sky Remote code for Sanyo LCD TV
I HAVE FOUND THE CODE AND SKY NEVER HELPED THE CODE IS AS FOLLOWS DEPENDING ON HOW OLD YOURE REMOTE IS 0065 IF YOU HAVE AN OLD REMOTE TAKE THE FIRST ZERO AWAY
Sep 02, 2008 | Televison & Video
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Sky remote code
codes for bush are
107
031
codes for bush uk are
005
038
140
018
052
143
020
058
152
022
085
169
031
107
172
036
121
175
015
043
141
019
053
144
021
078
156
026
099
171
033
109
173
226
196
hope this helps
Dec 08, 2007 | Directed 434MHZ Remote Control
Sky+remote code for my lg tv
The cose you need is 0206
Sep 15, 2007 | Televison & Video
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
