Question about Tools & Hardware - Others
How to put spring back in my ultra steel staple gun
2 Suggested Answers
SOURCE: how to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Posted on Jan 07, 2011
How to load
at the rear of the gun at the bottom is a spring loaded sliding rail, push it in, and pull down about 1/2 inch and than pull toward you either the staples will go on the rail or put the staples as if you want them to come out of the gun, push the rail back in and push the latch back into the gun so that that spring doesnt come shooting back at you. than the gun is ready
Apr 18, 2015 | Tools & Hardware - Others
CraftRight 3 in 1 Staple Gun
See that shiny steel saddle-looking clip at the "rear" (under your palm when you're using the gun) next to the bottom? Push it inward then down to unlatch it, then pull it straight out. Insert 12mm staples, push that thing back in and latch it again. It SHOULD be a little hard to push it - the long spring is what feeds staples up to the punch piston at the front.
Aug 07, 2014 | Tools & Hardware - Others
I removed top spring how do I reinstall and load spring
were you reloading the staple gun, now you want to put the spring load back in it to lock it to use it? slide it in, and push downward to lock it in.
Sep 27, 2012 | Arrow T25 Staple Gun
How do I load staples into my JT21 staple gun?
At the end of the stapler opposite where the staplers are driven out is a release.
Push it in and turn it and it should come out with a long spring
Load your staples, put the spring back and lock it.
Aug 31, 2011 | Arrow Fastener Co. Lt Duty Staple Gun -...
I loaded the stapler as described above. Now I hear the staples sliding around inside the casing. I loaded as many staples as the gun will hold. I pressed the handle down and three staples came out at...
You need to load just enough staples in it that when you put retaining spring and clip back in that it will let catch on back of spring to go into slot in frame. I hope this helps. Thank you
Nov 19, 2010 | Arrow T50P ARROW STAPLE GUN
Stanley TR 250 Staple Gun Staple cartridge problem
very simple to fix it 1 pull the trigger all the way out 2 there is a little piece of metal, pull it all the way out (detach the piece out from the gun) an connect one side of the spring 3 push the piece back on the gun. 4 on the other side of the spring tide a little fishing line 5 pass the fishing line over a small rounded piece and pull it hard 6 finally connect the side of the spring onto a little hock on the base of the trigger
Mar 17, 2010 | Stanley Tools/Goldblatt Tool No.TR150 Hd...
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
Can't get the staples to go in. It's a sears
Pull out the part that loads the staples, turn the gun upside down, put the staples in the bottom of the gun and push the loader back in. It took me awhile to realize that you don't load them on the piece that pulls out of the gun.
Cheers.
May 10, 2009 | Tools & Hardware - Others
LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Nov 08, 2008 | Powerfast Stanley TR110 Light-Duty Staple...
Tools & Hardware - Others Logo
161 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
