Question about JVC KD-G140 Car CD Player
How to set time!
Hi! I jus bought aJVC KD-G140 and i jus can't seem to set the time. Please help me i'm STUCK! Thank You
  • 8,197 Answers
Here you go.
http://resources.jvc.com/Resources/00/01/13/GET0485-001A.pdf
Good luck and please rate
Posted on Mar 14, 2009
How do i set clock on jvc kdg140
Press and hold SEL until menu appears
Using the scan button (FWD/REV), select Clock H
Using the volume knob/button, set the value
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
May 11, 2010 | JVC KD-G140 Car CD Player
Ive got a jvc kd g140 and it cuts out at high volume.
did you hook this head unit up or did you have some one hook it up for you? most of the time it is that factory amp that makes it cute in and out. take the head unit out of you car and hook it up with a 12 volt power in your house or on you battary with a speaker and if it still cuts out the amp chip need to be replaced. let me know if this helped. thanks.
Kim ( Owner )
KS AUDIO
www.ksaudio99.webs.com
ksaudio-99@hotmail.com
Jan 15, 2010 | JVC KD-G140 Car CD Player
Can't set clock i have a jvc kd-g140
hold sel for a few seconds then search threw using yer skip up and skip down button. untill u hit clock H then use yer volume botton to change.... then hi yer skip up again untill u hit clock M and use yer volume again. then hit sel to finish.
Nov 19, 2009 | JVC KD-G140 Car CD Player
Bluetooth turn on
Hello imback2009,
The JVC KD-G140 does not have a Bluetooth option, either built-in or with an adapter. And as far as I can tell, it doesn't have a "mute" or "phone" wire which would allow installation of a generic bluetooth adapter, such as the Parrot. If you want to connect your cellphone, I'd recommend you look at an upgrade here.
Hope this helps.
Sep 11, 2009 | JVC KD-G140 Car CD Player
Set clock on radio
Hello atesha23,
Below is the step-by-step procedure for setting the JVC clock. Please note that after you have entered the PSM mode, if you have not pressed a button for about 2 seconds, the radio will automatically exit the mode and return to normal operating mode. In that case, you must restart PSM by holding the "SEL" button until the display changes.
(1). Enter the PSM mode by pressing and holding the
SEL button until the display changes.
(2). Use the rocker switch left/right until "CLOCK
H" is displayed.
(3) Set the clock hours by turning the volume
control up/down.
(4) Press the rocker switch again until "CLOCK M"
is displayed.
(5) Set the clock minutes by turning the volume
control up/down.
(6) Press the SEL button to finish and EXIT.
Hope this helps.
Mar 31, 2009 | JVC KD-G140 Car CD Player
Setting the time
PRESS THE 'SEL" BUTTON MORE THAN TWO SECONDS AND THEN WITH THE KNOB VOLUME CHANGE SET HOUR THEN PRESS THE FORWARD BUTTON TO SET THE MINUTES WITH THE KNOB VOLUME THEN PRESS SOURCE.
Mar 18, 2009 | JVC KD-G140 Car CD Player
Clock setting on jvc kd-g140 car audio deck
Press the Mode button (M) and the display will flash mode. Then hold the select button (SEL) until it changes to display something else. Hit left and right seek until you find clock M and clock H. Hit select again and use the volume button to change the time! Took me two freaking hours to figure that **** out.
Jan 11, 2009 | JVC KD-G140 Car CD Player
I bought a jvc KD-G140 and when i try to save my preset buttons they dont save after i turn it off
Your description indicates that the yellow wire is not correctly installed/connected. It should be tied to the always on B+12 such as the battery + terminal or the main wire of the ignition switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 30, 2008 | JVC Car Audio & Video
JVC KD-G140 Car CD Player Logo
221 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
