Question about Emerson MW8102SS 1100 Watts Microwave Oven
Kenmore Microwave built in Model 665 606 52000
Kenmore microwave 665 606 52000 has a "d" message on control panel.No sound, can see operations but the buttons are not working correctly and no heat in oven.Electric power had obviously been interrupted before we came home.
Help!
Thanks,Karen
    Sergeant:
    Champion:
  • 234 Answers
Find manual and reprogram.
Posted on Mar 13, 2009
My over the stove microwave starts continues for a few econds the f-7 appears and it stops
F7 means power to magnetron is interrupted.
I don't recommend that someone without experience and an understanding of the safety procedures undertake troubleshooting this.
You can find manuals and helpful exploded view diagrams for your model here and my favorite parts supplier is here. There is a technical sheet hidden behind the controls that has helpful technical and troubleshooting information. It will say something like this:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See "Checking Inverters."
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
William E. Miller, AS-EET
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Oct 05, 2016 | Kenmore Microwave Ovens
Kenmore microwave displaying SE error message. How do I fix it?
That error indicates a bad keypad. You will have to replace the keypad/control console assembly.
Apr 22, 2014 | Kenmore Microwave Ovens
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 21, 2009 | Kenmore 63792 Microwave Oven
After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
Jun 19, 2009 | Kenmore Microwave Ovens
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
Kenmore Microwave 63301 - Power, but front panel doesn't operate
You have a failed membrane keypad or the problem may be on the board itself.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in most cases in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 30, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Kenmore 565.6050.9990 microwave dead
Start taking all screws out until you can access fuse.
Sep 17, 2008 | Kenmore 62622 Microwave Oven
Kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 13, 2007 | Kenmore 62622 Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
491 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
