Question about Makita Lxfd01cw 18-Volt Compact Lithium-Ion Cordless 1/2-Inch Driv
Makita cordless drill
When screwing in a screw it makes a grinding noise and won't screw in.
    Problem Solver:
  • 11 Answers
It sounds to me like the clutch is set to a low setting. Its the dial just behind the chuck with the numbers on it, you can turn it to adjust how easily the drill slips, the purpose of it is to make it easy not to strip screws or drive them in too far. Just turn it to a higher number or all the way and it should work fine. The setting its on is whichever number is on top of the drill (opposite the handle), there should be a little arrow on the body of the drill pointing to it. The highest setting will not be a number but an image of a drill bit, in this setting it will not slip at all. Some of these drills are also hammer drills (as the drill turns, the chuck will also "hammer" in the direction your drilling, this is for drilling into concrete and things like that and requires a special bit (if your drill has that there will be an image of a little hammer on the dial next to the image of the drill bit). I hope that helps, Good luck.
Posted on Dec 20, 2013
Minka aire f608 top won't screw on
Check to make sure your blades screws are tight. They could be rubbing against the glass.
Jul 01, 2013 | Minka Aire Ceiling Fan
Engine won't start. a grinding sound but wont fire.
Are you saying the starter is grinding but the engine is not cranking, or the engine is cranking and making noise and not starting ?
Feb 21, 2013 | 1991 Honda Accord
Makes grinding noise and belt won't move
If it sounds like metal rotating on metal then it could be a a(roller bearings or b( motor bearings. LUBE INMEDIATELY. + DECK BELT LUBE VERY URGENTE, MAYBE YOU HAVE A WORN DECK TIME TO CHANGE THE BELT.
God bless you
Oct 01, 2012 | Proform 380 Treadmill Walking Belt
I have a 1989 z24 cavilier and i just changed the slave cylinder and now when i start it and press the clutch it makes a grinding noise. When i try to put in gear it wont go in any gears and makes some...
hi i was wondering if anyone can tell me whats going on with my 89 z24 cav i just replaced two shifter cables on she's a 2.8l 5 speed and now when i starts her and lets the clutch out she dosen't engage at all but she has no noises and no grinding goes in gear fine but just won't move hope someone can help thanks
Jul 04, 2012 | Cars & Trucks
Car won't start but makes a grinding noise like when the car is started already
This sounds like a damaged starter drive gear and engine flywheel gear.
Feb 25, 2012 | 2001 Pontiac Grand Am SE
Washer makes loud grinding noise when turned on. We believe it is a problem with a belt, but we don't know how to remove the back panel to check.
The grinding noise you get is from the worn out ball bearings. Replace them. You can open the back cover by removing the screws. To fix new bearings remove the pulley & then the bearings.
sonsunny
Jun 15, 2011 | Washing Machines
Grinding noise
I needed to replace the nylon worm drive in my mixer. When I put it back together, I found that my mixer made a kind of grinding noise. The noise was due to a vibration associated with the cover for the electrical wiring in the back of the mixer. I solved my noise simply by loosening the screw to this cover. The cover is located on the back of the mixer, and the screw is on the top.
Separately, to find instructions for opening your mixer, you can go to http://neilcrockett.com/mixer.htm.
Jan 13, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Makita Lxfd01cw 18-Volt Compact Lithium-Ion Cordless 1/2-Inch Driv Logo
106 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
