Question about Sony Audio Players & Recorders
LPCH SHOWS ON FRONT OF RECEIVER - Sony Audio Players & Recorders
How to connect a turntable to a nad c730 receiver
Hi
You can get a manual for your receiver here
730 Stereo Receiver NAD Electronics
by clicking on "manuals and Downloads" and then the 7 language manual.
This will download the manual to your computer where it can be saved for future reference. Page 2 shows diagrams of the front and rear panels of the receiver and clearly shows that the turntable should be plugged into the pair of sockets on the left hand side (as you look at it) of the bank of 10 paired input sockets on the rear panel.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 26, 2014 | NAD C730 Receiver
AMP ERROR DISPLAY NO VOLUME
This is how to reset the receiver to factory default- not sure if it is the same reset you would do for an amp error:
Resetting the system
Use this procedure to reset all the receiver's settings to
the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the front panel STEREO/A.L.C
button, press and hold
u STANDBY/ON for about two
seconds.
The display shows RESET?.
3 Press the front panel AUTO SURR/STREAM DIRECT
button.
The display shows OK.
4 Press HOME THX to confirm.
OK appears in the display to indicate that the receiver
has been reset to the factory default settings.
Note that all settings will be saved, even if the
receiver is unplugged.
Unfortunately, amp errors are usually not fixable and require you to bring the receiver on for repairs or just buy a new receiver.
THANK YOU AGAIN SO MUCH! I basically got through the 1st step or so and the thing came right back on like nothing had ever happened. Although, I think what ended up working for me was actually pressing and holding the STANDBY/ON button with the AUTO SURR/STREAM DIRECT button together for a few seconds....I didn't have to reset to factory settings, nor did I have to do step 3 or 4.
Now the receiver is working just fine like nothing ever happened. All of the input AND output speaker channels all seem to be functioning normally and in peak form, and I've made sure that I have the area around the receiver well ventilated. So....thank you, again...for getting back to where I really wanted to be without having to go through the hassles of disconnecting everything and having it serviced with possible $ and time expenses.
Oct 16, 2013 | Pioneer DEH X3500UI - radio / CD / MP3...
I have a vsx92 that worked great up till my wife disconnected the hdmi cables to swap satellite to cable. Video runs through hdmi to the projector. I do hear audio, all cables are correct but I get no...
We had a similar problem, but was with the audio side. You can attempt the system reset like this;
Set MULTI-ZONE to OFF.
2 While holding down HOME MENU on the front
panel, press ? STANDBY/ON.
The display shows RESET ? NO ?.
3 Press ENTER on the front panel.
4 Select 'RESET' using ?/?, then press ENTER on
the front panel.
The display shows RESET? OK.
5 Press ENTER to confirm.
Hope this helps. I switched to Onkyo for my receiver.
Feb 08, 2011 | Pioneer Audio Players & Recorders
How do i reset my pioneer vsx 919 ah amp reciever back to its original settings
In the manual, page 72
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel
controls to do this. Set MULTI-ZONE to OFF.
• Disconnect the iPod and USB memory device from the receiver beforehand.
2 While holding down ENTER on the front panel, press ?µ STANDBY/ON.
The display shows RESET < NO >.
3 Select 'RESET' using PRESET +/-, then press ENTER on the front panel.
4 Press ENTER to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
• Note that all settings will be saved, even if the receiver is unplugged.
Feb 01, 2011 | Pioneer VSX-919AH-K A/V Receiver
I have hooked up my dish, yamaha receiver, CD player, blueray player and have surround sound for everything but the TV, Help!
Usually, unless the TV show is being broadcast itself in surround sound, the surround decoder in the receiver will default to front only sound on TV shows. When a TV show says that it is in surround sound, the receiver will decode it. I think the Law and Order series in broadcast in surround.
Hope this helps,
Best, Mark
Dec 30, 2010 | Yamaha RX-V463 Receiver
I have a Pioneer vsx519V receiver, I have connected two Boston cs226 speakers via the Front Speaker Terminals, I cannot get any sound at all - not even from the tuner (integrated) which shows that it is...
Check to make sure your the 'Speaker' switch is toggled to ON. Press the 'Speaker' button on the front panel. Or on the remote, press 'Receiver' button on the top left area then the 'Speaker' button on the bottom right area.
Oct 08, 2010 | Pioneer VSX519VK A/V Receiver
RECEIVER FROZE
Click here to find more info on how to fix your receiver. You will need to register to go to the Viewsat forum.
Good Luck.
Jul 31, 2008 | RCA DISH Network(r) 311 Satellite System
Receiver lcd display doesnot work
Does the 605 have the "pure audio" setting (my 705 does)? If that is selected, it cuts out the lcd display on the front.
Jan 04, 2008 | Onkyo TX-SR605 Receiver
POWER OFF alert
When you turn on receiver it will power off. Poweroff shows up and than turns off. if the front panal reads over load the output ic pac001a is defective i had repaired this model before
May 29, 2007 | Pioneer VSX-D710S Receiver
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
