Question about Olympus FE-230 Digital Camera
Power button seems to be pushed down too far --- I can't take any pictures either
I just tried to take a picture this evening with my new camera. Turned it on, but when I pressed the button to take the picture: nothing happened. I noticed that the power button seems to be pressed down lower than it usually is. Could this have something to do with it? I cant figure out what's going on with it. Thank you.
    Genius:
  • 2,985 Answers
Button stuck down! Try removing the battery to see if lack of power will return the button. If that fails take it back to the seller under warranty terms.
Posted on Aug 05, 2007
SOURCE:
On my 5800 xpressmusic the camera quality is not good. even i checked the quality on 5233 which has a 2MP camera...pictures are much clear than my phone.. please suggest
I have Nokia 5800 as well, but camera quality is good so far. Check your camera setting. Open Camera > Option > Setting > Click Photo quality > Drag the quality level to 3M - High > OK/Choose > Back to camera. Try to capture a picture and see if your problem get solved. And don't forget to click twice on capture button. First one is half push (like in digital camera) rather long until you get green box in the screen means the focus is ready, then push harder to take a picture.
Hope this help and if this helpful RATE please.
Feb 02, 2011 | Nokia 5800 XpressMusic Smartphone
The camera powers on ok BUT when the button is pressed .. it does not ever take a picture at present. Apart from not taking a picture .. other things 'seem' ok. Please help. merv1@iinet.net.au (email)
I have just purchased a DC 1000 under water camera. It powers up ok but I have to push the power button at least 3 times to turn it off. Often I have to hold it down on the third try. I have only had the camera 2 weeks. It did not do this when I first used the camera.
Nov 02, 2009 | Pentax Optio M20 Digital Camera
Takes a long time to focus / take a picture
According to your description, I would like to assume that your camera takes 9 seconds to get the flash ready, not to focus. If it is the focus problem, you need to send the camera for realignment or to replace the lens.
Here is my suggestion:
Try to disable the flash. Does it still take 9 seconds to take picture? If the answer is ‘no’, then try to use fully charged batteries or new batteries to reduce the flash charging time.
If you have a ‘batteries drain quickly’ issue as well, this tip may help: Why my camera keeps saying ‘change battery’ even with new batteries?
Jul 01, 2009 | Canon PowerShot S5 IS Digital Camera
When in Camera mode I focus and then prepare to take the picture but the as soon as I press the switch to take the picture the LG routinely switches from Camera mode to the Video mode. Why? I cant see
Well, this is the intended function of the button unfortunately.
If you press and hold down the camera button, it toggles between camera and video.
However I'm sure you have noticed that on occasion, if you don't hold the button down long enough, no picture is taken.
It turns out to be something you just have to get used to. There is like a 2 second delay on the toggle so just don't hold it down that long. It is hard to get used to if you are used to a red eye removable flash or a slow camera button as found on many new cameras.
Here is a tip though, after you take the picture to quickly take another picture, you can fast save the photo by pressing the camera button again instead of messing with the touch screen.
May 22, 2009 | LG Dare VX9700 Cell Phone
Wont take pictures
well , ive got exactly the same camera , and basicly when i take a picture i just press it down all the way , it seems to work for me and my friends who have the same camera
Dec 26, 2008 | Kodak EasyShare C713 Digital Camera
Exposure wheel does not seem to have the proper range.
the scroll button is already losing contact that why is not working properly..use a lighter fluid to the button then roll up and down untill the button is clean don't put to much fluid ok...
Aug 06, 2008 | Sony Handycam CCD-TRV68 Camcorder
My camera wont even turn on
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Apr 01, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
Blurry Image
I had that problem too. So I pushed the MENU button and got to looking to see what all was there. I moved down to where it says SCENE and clicked on it. I moved it down to portrait. On my camera that fixed my problem of no flash and it seemed to take forever to take the picture. You could try that. But I did notice though, that when I turn my camera off and then back on I have to re-do it.
Sep 10, 2007 | Vivitar ViviCam 5100 Digital Camera
Quality of pictures, camera does not focus
Has this has a knock or been dropped? Whether it is fixed lens or motor Zoom only such treatment would make the lens shift out of the focal plane Try technical support of the makers website. If it is failry new there may be an exchange option.
Jun 22, 2007 | Concord Camera Eye-Q 4060AF Digital Camera
Olympus FE-230 Digital Camera Logo
49 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
