Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv turns on and channel continually scans
Remote doesnt work
cant get tv to stop scanning
video/tv button on set will not work
basically unresopnsive
  • 1 more comment
  • wjmctdog_100 Mar 13, 2009
    all buttons are free in fact we never use them
    when the tv is turned on it is not scanning
    you turn it on and touch any button on the set it begins to scan but channel remains the same that you are viewing,
    I also can't access the menu from the set or the remote
  • wjmctdog_100 Mar 14, 2009
    By scanning I am referring to the constant rolling through channel numbers in the top right corner. I looks very similar to when you scan for signals using the menu, except the channel you are viewing remains the same and the green digits continually roll through the numbers.
  • 89 Answers
Sounds like you have a collapsed channel up or down button, Does each button have a good "rebound"?
if any of the buttons are stuck in, just release them
Posted on Mar 13, 2009
  • wayne chamberlain Mar 13, 2009
    Could you define scanning please, usually I would take that to mean that the channels are being programmed and the unit is contsantly changing channels, However you state that the same channel remains visible
    Is it scanning in a Picture in pictue window?
Set stations
A channel scan is a vital part of utilizing your cable TV service. When a coaxial cable is connected to a TV, sometimes it will not display any channels until you configure the TV for your specific cable connection and scan for available channels. A channel scan can be applied to basically any type of TV or TV/VCR combo, even if you are missing its remote control.
Read more : http://www.ehow.com/how_6875646_do-old-tv_vcr-tv-remote_.html
Instructions
    • 1 Bring up the TV's menu. Look for a button on the front panel of your TV/VCR labeled "menu" or "setup." Press it and you should see a menu appear on the screen. Part of the menu should inform you what buttons you can use to navigate through the menu. If not, try using the volume buttons or channel buttons on the front of the TV and see if pressing those allows you to navigate through the menu.
    • 2 Specify channel scan settings. Once you are able to navigate through the TV's menu, look for the "channel scan" "auto-program," or "auto-tune" option. This may be inside one of the TV's sub-menus such as "setup," "channel setup," or the like. The key of this step is to specify your cable settings before running your channel scan. The "tuner mode" option needs to be set to "cable" rather than "air" or "antenna." You may have to specify what cable type to use, this will be set to "std" or "standard" for the vast majority of cable providers. If you are not certain what cable type you use at home, contact the technical support department of your cable provider.
    • 3 Run a channel scan. Once the scan settings have been set properly, run the scan (usually done by pressing a "start," "scan" or "begin" button.) When the scan is complete, check to see if you are getting all of your channels. Contact your cable provider if you are not sure how many channels you are supposed to be getting.
good luck
Jan 08, 2015 | Televison & Video
Why is my remote control not working despite changing the batteries.
Not sure if this will help but, I recently put an antenna on the roof of my house. I don't watch TV much but wanted to enjoy some TV, but my remote locked up and the side buttons on the TV wouldn't work either. I tried changing the battery, but no luck. There's a broadcast station 64.2 that is locking up TV's & remotes. Here's the fix that a TV repair co. gave me which did break the lock of the station 64.2.
1) unplug antenna (not roof but connection from TV to wall)
2) unplug and plug back in TV
3) find a way via remote or side buttons to scan channels
4) Go to Menu
5) EZ Setup
6) Channel Set Up-Scan Channels
7) Channel Memory
8) Digital Set Up
9) Turn Skip On for 64.2 (Delete this Channel)
10) Turn off TB
11) Hook Antenna back
You may have to play with the order to acheive the end result or figure out a way to delete 64.2, but during the process you will at least unlock from being stuck on 64.2.
Good Luck if this was the same issue!
Jul 14, 2014 | Audio Players & Recorders
My LG TV doesnt respond to remote control. it works when i operate it manually but as soon as i press any button on the remote, the channels keep running on their own. none of the buttons appear stuck.
First thing I would suggest is have the remote tested--understand the remote and the buttons on the set go to same place--buttons have priority-
A remote can be tested--most testers you point the remote at and press any button and the tester flashes briefly--in this case if it continues to flash something got spilled inside the remote--this can be dealt with usually--also some digital cameras with them on it can be pointed at and same thing done--will see momentary flash on camera screen--if press a button and continues to constantly flash--it likely is the channel buttons on the set (up if channels scan up and down if they scan down.)
NOT likely but possible the problem is in the set--checking the remote will tell that--if you get that far I can give you general instructions about taking the remote apart and what to look for and do.
Test remote first---no sense in taking it apart until you know--got any friends with a similar LG you could test your remote on their set.
Apr 09, 2012 | LG 42LC2D 42 in. LCD HDTV
Cant get cable tv
Hello
First connect the cable to its cable input socket at rear.
Turn the tV On and enter its Menu option window. Press UP or DN button on the remote control to select 'Cable'. Selecte EZ scan [channel search]. The TV must scan for all available channels, and will stop after all the channels has been stored in its memory. You have to wait till the search function stops; no other functions with remote cannot be done, and the set will not respond any external command, either by remote control or by its front panel control, except the mains power ON/OFF switch will work. OK.
Nov 21, 2011 | Zenith Z50P3 50 in. Plasma TV
I need to re-program my toshiba tv to get basic channels after i just had th cable box removed. how do i re-program it on the remote?
But u still have and pay for the basic cable service wright?Yes,just used the tv remote and push the remote menu button than go into the tv menu,go into Setup enter and go down and pick CABLE not AIR.Enter for the tv do scanning for cables channels.After finish scanning u will get all the basic cable channels.
Jul 13, 2011 | Toshiba MV13M2 13 in. TV/VCR Combo
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Mar 24, 2011 | One For All URC-4021 Remote Control
My Volume and Channel button won't work and so I have bout 2 remotes, neither of them have worked, one is the RCR311BR remote which has been noted to work for this tv. What else can I do
I have a 2000 model RCA P52923 and I had the same problem occur a couple of days ago. The sound hasn't worked for a couple of years, but the TV is connected to an RCA surround sound to resolve that issue. Most recently, while watching TV, it began to start scanning channels by itself. I shut it off and unplugged it for a couple of days, but each time that I turn it on, it begins to immediately start scanning each channel. Neither the remote, nor the channel buttons on the set are able to stop the scanning, and neither of them will perform any functions, including turning the set on and off.
Any advice would be greatly appreciated.
Mar 11, 2011 | RCA P52926 52" Rear Projection Television
I have a emerson 32 inch tv ewf2702. The remote does not work
try scanning your TV channels down or up depending how close you are to the first or last channel you have programmed, if you continue to move past those settings you should come to the game channel for your TV, if it does not go into your menu>channel settings>manual settings, scan to the game channel and make sure it lists as active if not make it so.
Dec 07, 2009 | Televison & Video
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Auto Scanning
Try unplugging it for 2 minutes then se what happens. Make sure that none of the buttons on the TV or remote contol are stuck (especialy if remote is near TV).
Feb 06, 2007 | Audiovox FP1510 15 in. LCD Television
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
110 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
