Question about Sony PlayStation® 3 (80GB) Console
Can't watch dvds on playstation 3
I have power cord & hdmi cord connected to hdmi large tv. do i need any other cords connected from playstation 3 to tv?
  • 89 Answers
No, but you do have to select HDMI output in the settings in the PS3 menu and make sure the TV is switched to the correct HDMI input ( Whatever one you plugged your PS3 into)
Posted on Mar 13, 2009
How to reset my ps3
Amanda, check your connections. Are you using the RCA cords, or HDMI? The PS3 can run the HDMI, but it's not as stable as the RCA cords provided by SONY. However, the HDMI connection is the only way to get the 1080dp or Hi-def video from your system. If you were using the HDMI and are switching back to the RCA cord, the system will NOT auto-recognize the connection like it did with the HDMI. You will have to either connect the system to a TV with HDMI, then manually change the connection type, or do a video reset on the system. Pretty easy to do. Simply turn on the system, and while holding the power button, wait for the second "beep" After you hear the second "beep" take your finger off of the power button and watch your screen. YOU HAVE SUCCESSFULLY COMPLETED YOUR FIRST VIDEO RESET!!! ^^It should turn on, but may take a moment. Sometimes it's instant, sometimes it can take about a minute. This works for ALL PS3 models.
Aug 12, 2015 | Sony Playstation 3 (PS3) Console
My ps3 turns on but no picture
First, how are you connecting? RCA jacks(red yellow white cords) or HDMI? If it's the RCA cords, they were known to develope shorts in the yellow cord that connects to your TV. Just try another cord. They are very cheap, and the cords from all of the other Playstations will work for the PS3. Second, try to do a picture reset on your system. Sometimes, going from HDMI, back to the RCA confuses the system because the RCA connections are NOT detected automatically, HDMI is. To do a picture reset, turn the system on, then push the power button once,(you'll hear a beep) then push and hold the power button until the system shuts off.(you should hear 2 beeps) Then when you turn the system back on, the picture will be reset. ^^ Good luck, and I hope this helps.
Dec 06, 2014 | Sony Playstation 3 (PS3) Console
I have my ps3 plugged in but powered off so just a red light is on.i push power button light turns green I hear fan come on and everything sounds normal but it has no picture at all.it takes cd no pro
Rudy, are you connecting to the TV with HDMI, or RCA cords? HDMI carries both picture and sound thru 1 cord, whereas RCA splits it to YELLOW RED and WHITE. The HDMI connection is automatically detected when connected to your TV. It will say"HDMI is detected, do you want to use these settings?" RCA is not automatic, and is prone for the video(YELLOW) cord to develope a bad connection. I wouls duggest first replacing the cord. They are inexpencive, and the fastest way to check your issue. I am going to include a link to a youtube video that will guide you through the steps on how to reset your video settings on your system.
How To Reset PS3 Video Settings PS3
Oct 08, 2014 | Sony Playstation 3 (PS3) Console
Cant hook up through my hdmi connection
You need to reset the PS/3... this resets the video out format
Aug 28, 2017 | Pioneer PureVision PDP-5050HD 50 in....
The playstation 3 wont connect to the tv it all
Sounds like a bad hdmi cord...if the a/v works.
Jan 03, 2011 | Sony Playstation 3 (PS3) Console
Hdmi port on back of tv does not work
Have you tried a new hdmi cable. They break easily
May 10, 2010 | LG 26LG30 26 in. LCD TV
Everytime i try to plug the hdmi cord inot the playstation it shoots sparks out and flips my breaker. 2 times, t different hdmi cords...what do i do!? I cant use it..
You might want to try connecting everything unenergised. Shut everything down (turn off buttons on both ps3 and breaker). You may even try unplugging the breaker from the power line. Now connect the HDMI PS3 to TV, audio cables, etc. Energise everything and turn on.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Help!
It is possible that the HDMI ports are blown. The work through their own circuit area in the TV set. This is a particularly complex area.
You will have to send the set to the authorized service rep for an estimate. See if your home insurance plan will cover for this type of thing. Some types of home policies will cover for this type of thing. The cost of servicing your set may be expensive. Damage from a lightning strike will not normaly be covered by warranty.
Jerry G.
Jun 12, 2008 | Mitsubishi WD-Y657 65" HDTV
Hdmi cord causing purple and green lines
It may be a ground loop caused by cable televisoin and the Ps3, as PS3 uses a 3 prong plug. Try unplugging the ps3 power cord and see if the lines go away. If they do, it is a ground problem...usually with cable tv. If this is the case, try a good quality power bar with cable suppression jacks on it. It will help eliminate the ground loop in most caese.
Dec 28, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (80GB) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
