Question about Abit KD7 Motherboard
Motherboard doesnt post if you change any of the settings
I got an old abit KD7 from a friend, it boots up fine if default settings are loaded but if I change anyone of the the settings it will not post. I am trying to change the boot order so I can reformat the Hard drive. Their are no beeps or anything and the latest bios is loaded on it.
  • 1 more comment
  • Anonymous Mar 13, 2009
    I have tried 3 different cmos batterys and non of them worked. The computer boots on default values but if I change something in the bios is still doesnt post
  • pizza44 Mar 13, 2009
    I'm only changing one setting. First boot from floppy to cdrom, no overclocking, everything is at default settings
  • 41 Answers
Sounds to me like you have a bad CMOS battery. That battery provides enough juice to keep the hardware clock and settings active. The battery should be a size 2032 and you can find a energizer brand at any store almost. Shouldn't cost more than a couple of dollars. Let me know if that does the trick.
Posted on Mar 13, 2009
  • Bill Kindle Mar 13, 2009
    Are you trying to over-clock or what are you trying to change?
How to acsess the boot device menu at post on abit il8 motherboard
.Abit did not add the BIOS post to the manual.
Watch the BIOS post, most all motherboards have the hot-key menu at BIOS post.
If for some reason the hot-key is not reported on BIOS post, then you hit the DELETE key and enter the BIOS, Advanced BIOS Features Setup Menu and set what hardware you want to boot first, under Hard Disk Boot Priority, set First Boot Device
Mar 31, 2013 | Abit IL8 Motherboard
My computer is dawn
Check your ram sticks one or both could be bad that could be the reason for system beeps and not booting ( open system remove one stick and restart system. If system still beeps shut down replace ram stick and remove other stick and reboot) . I hope this solution goes well for you.
Mar 03, 2013 | Abit KD7 Motherboard
When i boot up the computer it starts beeping immediately, otherwise boots just fine
The beeps are part of the boot sequence, more normally called the post report. The beeps length and number usually indicate a problem.
Check with the abit website, you need the post sequence for your motherboard.
Usually, with a post report, you get a single beep which means everything is tickety boo.
Feb 06, 2011 | Abit AV8 Motherboard
I have an abit kd7 raid mother board and just installed 3 1g sticks of pc3200 400mhz and the bios only reads up to 266 any help
Is the board rated for the faster speed? Just putting in faster chips will not work unless the motherboard supports that speed.
Mar 26, 2010 | Abit KD7-RAID Motherboard
Abit AN7 motherboard does not boot - POST code AF
i think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
May 09, 2009 | Abit AN7 Motherboard
IDE Primary Master/Slave NONE
Hook the two together on the one working IDE connector. Put your hard drive as the first device on the ribbon cable and make it the master using the jumper at the back. Hook the DVD to the second and set it's jumper to slave. Install your OS then try to figure what's up.
Jan 03, 2009 | Abit KD7-G Motherboard
Usb power always on.
try setting up your CMOS by setting it to optimized default settings, then save and exit. turn off your computer, plug off the power cord from your Battery Backup or from your AC supply. if still didn't worked out. try replacing your power supply
Dec 13, 2008 | Abit Computers & Internet
Abit KD7 Motherboard Logo
130 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
