Question about HP Pavilion N5270 (F2363M) PC Notebook
Need new modem?? NO dial tone.
HP Pavilion n5270. laptop. Has no dial tone. Tried everything, ran system diagnostics. Said it was fine. So now am figureing just gonna get a new modem. SO.....where do I find one for this old thing and is it easy to replace?? What should I be looking at pricewise to have someone put it in?? Reformatted the thing also. It has only the bare bones stuff on it now that came with it. I can get on with my ethernet but am selling this to someone who only has dial up. Oh have also gone online and got updates for ME too including drivers. So dont know what to do. Wish I could get it working without having to buy new modem. Any ideas? I am not too detailed but dont know what else to tell ya. Thanks so much.
  • 370 Answers
Posted on Mar 14, 2009
I have a hp compaq nx7400 laptop with an agere systems hda modem.i have a dial tone and when i try to connect to the internet the modem sounds like it is dialing but the dial tone never goes away.is the...
The Agere systems HDA modem is a 56kbps modem typically found on laptops. View it in device manager.
Start->Control Panel->System->Device Manager->Modems
Should be listed there. See if there is an exclamation mark next to it.
Not very expensive or difficult to replace
Aug 14, 2010 | HP Compaq Business Notebook nx7400
I have a dial tone, but will not dial .I have a HP Pavilion computer and use a dial up service. I delt with HP on this 4 months ago and they sent me a new modem, and curred the problem. Now the problem has...
If it is a USB modem, connect it to a different computer, and try it.
If it fails to connect, with _two_ different computers, then the problem is in the modem, not in your HP computer. Give that information to HP.
Or, switch to high-speed "lite" (as in "lite beer"), for about the same amount per month as for dial-up, and throw the modem away.
May 13, 2010 | HP (56K V90 USB) Modem
Dial up not working on Vista laptop
OK some of the obvious then, have you installed everything in Administrator Mode, & have ALL permissions set, and Installed in XP SP2 Compatibility Mode. is Vista (Ugh) actually dialing?
Jan 28, 2010 | HP Pavilion dv1000 Notebook
HP USB Modem does not break dial tone
If the information connected to your post is all correct (56k V90 usb), and you are using one line for both the internet and the fax, you should hang up from the internet before you try to dial out the fax.
You have not indicated your PC model, so I don't know what operating system you are using. For XP and newer versions, you have to set up and configure the fax using the wizard or configuration software. If you have not done that yet, you need to.
In xp, go to start, Programs , Accessories , Communication , Fax , and then click Fax Console.
You said your computer is new. Win 7 and Vista are much the same:
1.Click the Start button , click All Programs, and then click Windows Fax and Scan.
2.At the bottom of the left pane, click Fax, and then click New Fax on the toolbar to launch the Fax Setup wizard.
3.Click Connect to a fax modem and follow the instructions.
You also need to make sure that your fax/modem is correctly listed in the control panel. In XP, start, control panel, printers and devices. If you do not have a fax printer listed, you need to "install a local fax printer."
The installation wizard should work in both OS without much trouble. If you do have difficulty, Microsoft and adobe both have "virtual printers" you can use. Look in Microsoft office or online.
Also check control panel of 7 to make sure that your modem and fax are listed correctly. Thanks for using Fixya.
Jan 01, 2010 | HP (56K V90 USB) Modem
Hp problem
Try to make a new connection shortcut and make sure your telephone line is properly connected on your modem. Also make sure that your password and username is correct. another thing is check that your system date is correct.. Hope this works ! ITTech7574
Aug 28, 2009 | HP Pavilion a6863w-b PC Bundle with 23"...
HP pavilion dv5-1125nr notebook, dial up modem is not working
Save yourself alot of grief. Purchase a PCMIA or USB modem and your done. A very inexpensive fix. I am a certified HP Master tech and I will tell you that HP does have some consistent problems withg their modems. If you can spare a few bucks go to www.driveragent.com and try to locate an updated driver.
Jul 30, 2009 | HP Pavilion dv5-1125nr Notebook
Modem, Dial Up Connection Problem
here's some help...go to : start menu,all programmes,accessories,communications and to hyper terminal..type in test, and click o.k.,make sure all the settings are o.k., type in your mobile or your second land line number to test if the modem dials that number.if that test works then contact your i.s.p to check on your account.
Sep 03, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Compaq V2615 dial up connection
plz check your phone line. then u scan your pc for anti-viruse and anti-malware in safe mode. then uninstall the modem drivers and modem through safe mode. Reinstall the modem drivers if still u cannot connect then your modem may be out of order.try a new one.Still problem persist than u check it with your service provider n tell them to check for the data part of your phone line
Mar 31, 2008 | HP Compaq Presario V2000 Notebook
Modem replacement inspiron 2200
Do you have access to another laptop that you could test the new modem in? Sounds to me like the new one maybe faulty :(
Try uninstalling the old one whilst its in via device manager then shut down and put new one in. If it doesnt detect it then its faulty.
Dec 28, 2007 | Dell Inspiron 2200 Notebook
HP Pavilion N5270 (F2363M) PC Notebook Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
