Question about LG GMA-4082N DVD±RW Burner
My GMA-4082N only recognize DVDs, but not CDs
The problem occoured yesterday when I was trying to read a CD, but after inserting the CD, the light of the drive blinked and nothing happened after 20 seconds, then it tried to read or write ... failed. I tried also all CDs I have, failed. Amazingly, when I was trying any DVDs for reading and writing, it worked perfectly... I thought I might need to reinstall the OS, but this didn't help since the installation is via CD. Anyone has met this problem before or anybody has ideas for this? Thanks!
Gaaaad dang it. same problem here. this is the last toshiba laptop i'm getting, the last 2 out of 4 have had severe problems such as audio jack port failure, vertical bands on the screen...
Posted on Feb 05, 2008
  • LG Master
  • 12,061 Answers
This is a common problem I have seen over the years it appears that the Laser for the CD, burns out, or the detector for the CD side of things fails..either way it usually results in DVD working 100% BUT the CD side if things is no good... Unfortuanatly it means ya gonna have to get another unit :(
Posted on Aug 05, 2007
SOURCE:
Does not read Cds or DVDs
most sony CD and DVD players have a digital signature design to play CDs and DVDs that are original and licensed. some CDs or DVDs dont work since the player does not recognize or scan any digital signature embedded in the CD or a DVD. 2nd, lens problem causes most players not to read CDs nor DVDs. you can try to buy CD or DVD lens cleaners to have your lens cleaned.
Nov 01, 2010 | Sony Computers & Internet
GMA 4082n device driver not working properly code 39
The dvd does not need driver, you need to reinstall Windows.
Jul 18, 2008 | Toshiba Satellite A135 Notebook
Cd rom is not reading CDs
1) The CD you're trying may be defective or empty. Try a different CD, one that you know for sure is good, maybe a music CD.
2) The lens may be dirty. Open the cd door and blast some compressed air into it
Mar 19, 2010 | Dell Studio 17 Laptop
Does a hl-dt-st dvdram gma-4082n write to dvds? I
Yes, the DVDRAM will write to both CD's and DVD's. It supports single and dual layered DVD's.
Regards.
Nov 16, 2009 | HP Computers & Internet
Combo Cd/Dvd Drive is not reading Cds nor DVDs
1. Remove your burner from your computer then open it by removing the screws under the burner.
2. When the cover has already been removed, get a cotton bud then soak it in alcohol to clean the lens. Because the lens might just be dirty. Then after that put the cover back by screwing it again then install it back to your computer.
Apr 08, 2009 | LG GMA-4082N 8X SLIM DVD RW DRIVE FOR...
Dvd drive will read/play dvds but will not recognize a cd
go to safemode and try reading CDs in safemode. If your burner still can't read CDs then it's most likely bad. You could get an external usb burner.
Mar 18, 2009 | HP Pavilion dv4000 Notebook
HL-DT-ST DVDRAM GMA-4082N. Can not write to DVD
The DVD -R +R means that you can read these types of DVDs that have been created elsewhere, it doesn't mean you can write to your DVD under the format of -R or +R. The CD is a CDRW which means you can read and write to CDs.
I don't think that a factory Satellite P100 has the ability to write to either DVD -R or +R, but to only CDs. I have a P200 that has a DVD -R +R/CDRW and it can't write DVDs. These DVDs you put in are for read only. My Toshiba A215 can but it's a DVDRW/CDRW.
Feb 15, 2009 | Toshiba Satellite A135 Notebook
LG HL-DT-ST DVDRAM GMA-4082N stopped reading some dvds
I also have had the same problem with my DVD drive. I Downloaded the new updates from the Lg.com website and Walaaaaaaa!!!!!!!! the problem has been Solved. Do the same for your dvd drive and you also can get your problem solved..........
Jan 18, 2009 | Computers & Internet
First go into Setup (usually F1,F2 or del) at start-up. See if your drives show up there. With Windows running, right click My Computer, left click Properties, left click Hardware, left click Device Manager, left click DVD/CD-ROM drives. Also check IDE ATA/ATAPI controllers. Do the drives show up there? If they do right click on drive and left click Update Driver. If they are not there go back to System Properties and left click on Add Hardware Wizard. This will search for devices. It may ask you to insert Windows CD which of course you can not do because the drives don't work. Try a different drive. When you cleaned out your computer did you delete or uninstall Office? That may be what caused this problem. None of this may work but it is a starting point.
Jan 06, 2009 | Dell Dimension 4600 PC Desktop
check whether the device is detecting properly on bios or not
Oct 01, 2008 | Computers & Internet
Open Questions:
See all LG GMA-4082N DVD±RW Burner Questions
LG GMA-4082N DVD±RW Burner Logo
212 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
