Question about Century Portable Plasma Cutter 82021
Can you weld with out gas with a century 90gs 117-086-000 #83095
    Problem Solver:
  • 14 Answers
I think you can if you have compressed air feeding in to the unit.but dubble check on there email sight first berore you run it that way hope that helps jojogunne
Posted on Mar 15, 2009
Will a ya219b snap on by century mig welder weld flux core wire
Are you using knurled rollers? Check the wire. Is it reversed polarity. Flux cored wire is very voltage sensitive.
Jun 14, 2012 | Century Welding Tools
I have a century powermate 70 mig welder and using .30 fluxcore wire. the machine says that it is gasless also. the machine will not weld right. is this the right wire or what could be wrong?
Check that your ground clamp connection to the weldment is secure (tight).
you can weld with the shielding gas, or without.
by not welding right, what exactly do you mean?
Jun 29, 2010 | Welding Tools
Was welding and welder quit acking wire feed and gas still work i have a century pro wire welder model 170gs
Check earth wire has not become dislodged,
Pop the cover and check for burnt terminals, often overheating of the transformer can cook a terminal, easily cleaned up and replaced.
Mar 31, 2010 | Welding Tools
My welder no longer produces high quality welds
You could have a poor ground clamp connection. Check that. also increasing the gas flow will cause turbulence at the weld, this can have a negative effect on weld quality.
Check your connections, check your liner, actually, replace it if you haven't recently.
Feb 15, 2010 | Lincoln Electric LE 83180 Century...
I have a century 140 welder It does seem to have any power. I'm using .023 wire with co2 gas and with the welder turn up as high as it goes the weld just beads up without any penetration and I was only...
That doesn't sound right. Double check your ground and the tip the wire feeds through -- if it is damaged/worn/burnt it will not transfer full power to the wire. After that, it would be time to check the connections from the transformer to the leads for dirt/loose connections.
Nov 18, 2009 | Welding Tools
Century Portable Plasma Cutter 82021 Logo
253 people viewed this question
Top Century Welding Tools Experts
John Trevino
Ted Maxwell
Tom Chichester
Are you a Century Welding Tool Expert? Answer questions, earn points and help others
