Question about Cannondale Scalpel 3000
How do you replace the lefty fork battery? - Cannondale Scalpel 3000
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: how to dismantle cannondale lefty
http://www.cannondale.com/usa/usaeng/Instructions
select Lefty in the right side rolldown
Lots of manuals
Posted on Feb 27, 2011
How do I fix an oil leak on my cannondale lefty
First try to replace the oil and replace the oil seals then inspect the tubes for scratching/gouging while you have them apart.
Sep 25, 2014 | Cannondale Lefty Alloy Dlr Mountain Bike...
How do I adjust the front shocks on my Genesis 29 mountain bike?
Sometimes there are adjustable knobs you can turn on the top of each Stanchion, one for left side of the fork and one for right, righty tighty, lefty loosey. otherwise it's just a fixed fork. You can service the fork by unbolting the innards at the bottom of each side with a hex key/allen key, but i'd look up on fork suspension maintenence before you do that...
Apr 19, 2014 | Cycling
Fore and aft play in a 2009 lefty speed carbon w/ fox rlc
A lefty fork can be dificult. I would bring mine to a bike shop. It's probably the headset, which if threadless, is common and a 2 second fix. I don't know enough about lefty forks to say for sure though.
Jul 16, 2011 | Cycling
Shipping a bike. dismantling instructions; front fork in particular
Since there are a lot of varieties of the Lefty go here and search the list for "LEFTY".
http://www.cannondale.com/manuals
Or you might just get away with deflating the pressure preload and collapsing the fork.
Jul 02, 2011 | Cannondale Lefty Alloy Dlr Mountain Bike...
I just bought a used Cannondale lefty fork. I was told that it can be stiffened by placing a pump on the bottom of the valve to add air into the fork. Problem is, the valve stem is so encased in the fork...
Hello ledpencil,
Pneumatic bike shocks require a special type of pump called a "shock pump" that is a high-pressure (up to 300psi!) but low-volume pump. They come with a very accurate gauge, pump handle, and a bleed valve/button to let off puffs of air to soften the shock. They also have a long flexible neck that screws onto the valve at the base of the fork. They're relatively small and moderately priced ($20-$40) and can be packed in a riding pack in case you want to change the stiffness on the fly. Here's a link to some online: http://www.jensonusa.com/store/sub/292-Pumps+And+Co2+Inflation-Shock+Pumps.aspx?s=1559&mfg=0&closeoutHotdeal=&use=&sort=Default&show=25&pricemin=0&pricemax=100
Hope this helps! -The Chicken
Apr 01, 2011 | Cannondale Lefty Alloy Dlr Mountain Bike...
Will the cannondale xc3 mtb stem fit on my lefty headshock? And how do I do it?
the XC3 stem comes in a 1.5 in clamp designed to fit on cannondale headshox systems. The lefty fork you have may or may not be compatible, you would have to check your fork to see if it is the right size.
There is an XC3 SL conversion kit for lefty forks that are not the same size and includes the stem and steerer replacement.
Swapping stems is quite easy on the cannondale. Loosen the two bolts holding the stem to the steerer and undo the bolts holding the handlebars, remove stem and replace.
If none of this makes sense then I would strongly urge you too take the bike into your local bike shop, preferrably a cannondale dealer, and have them show you. It will take only a couple minutes and they can confirm compatibility.
Jan 06, 2011 | Cycling
How to dismantle lefty
Hi!
The Cannondale Lefty fork can only be disassembled with speciality tools. You can read illustrated instructions here: http://www.gordlaw.com/index.php?Cycling:Cannondale_Lefty_DLR
Please check that your Lefty fork is identical to the one described, as the process and tools are different for the various Lefty editions.
As a warning, dismantling the fork could lead to serious injury if you don't know what you are doing. Please read through and understand all instructions before deciding whether to do it or not. Good luck.
Apr 04, 2010 | Cannondale Road Mountain Bike Bicycle U...
Cannondale Scalpel 3000 Logo
104 people viewed this question
Top Cannondale Cycling Experts
Charles T Nevin
Charles T Nevin
dante
Tom Chichester
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
