Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
REMOVAL OF DOOR PANEL on a 1995 Chevy C1500 Pickup
I need to remove the door panel on a Chevy C1500 Pickup so I can repair the Door latch that came loose and is ratteling around inside.. Can you tell me (Step by Step Please) How to remove the door panel??
Take a clean rag and work it behind the window crank to remove clip. Then remove the 2 screws in the armrest. I used a plastic shoehorn and started at the bottom right hand corner of panel and popped the plastic pins from the retainers. Pull the panel away from door and yu'll see pin holding door handle assembly . Undo the pin and replace assembly. Installation is the reverseo
Posted on Nov 06, 2011
  • 165 Answers
Posted on Mar 19, 2009
2005 envoy drivers door wont open from inside or outside
Linda, The door latch linkage is probably damaged or fallen off inside the door. Pop into a good body shop and have them check the door lock/latch mechanism for you. The body shop rates tend to be more reasonable then dealership for this type of repair. Links below are just to give you an idea of what may be involved in repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GMC Envoy door panels remove and install front and rear
How To Install Replace Broken Power Door Lock Front Chevy Trailblazer GMC...
Chevy Truck Door Latch
How chevy door latch works
Jun 22, 2016 | 2005 GMC Envoy
How to remove glove box
Open the Glove Box and remove the screws that are hidden by the lid and maybe the striker part of the catch that the latch hooks to.
Jun 24, 2014 | Vehicle Parts & Accessories
Change outside power mirror on gmc c1500 sle truck
Remove on inside door panel. remove three (3) 10 mm nuts and remove mirror... door panel if you never removed one is the chalange
Mar 25, 2013 | 1998 GMC C1500 Pickup Door Mirror...
Repair panel driver seat on1999 chevy suburban
Remove all screws, be sure to look carefully not to miss any. Usually in the armrest of the door, and up by mirror. Then using a plastic spatuala or equivilant carefully pry the plastic panel from the door a few inches at a time
Jul 23, 2012 | Metra 99-4544 1995-1999 Chevy C1500...
Passenger door stuck shut, need to access fuse panel for other electrical problem. It feels like the linkage is snapped somewhere behind the interior panel. Any tricks before I cut into the panel to access...
Don't cut the panel. You can pull the panel away from the door starting at the bottom. You will have to remove screws holding the arm rest and door handles off to remove the panel completely. The panel will snap back into place after you have repaired the linkage for the latch.
Dec 24, 2009 | 1995 Chevrolet Lumina
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
How to install replacement door handles for 98 ford ranger pickup
remove interior door panel(need special tool to pop plastic clips holding panel to door)with panel off remove plastic film,with window up you should be able to see two 10m nuts-bolts to remove-also have to pop lever off that goes down to door latch
Sep 19, 2009 | 1998 Ford Ranger SuperCab
1995 chevy pickup won't start
I would start with the fuse panel. Any blown fuses? Replace an dtry to start. On the firewall is a cover on the passenger side. Remove the cover and make sure the power is there. Check with a test light. The fuel pump relay is also there. Test is and also test the distributor and coil.
Hope this helps, rate me high please.
RPM Northwest
Feb 07, 2009 | 1995 Chevrolet C1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
1,387 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
