Question about Mitsubishi WD-62526 Projection TV
When turned on, my Mitsubishi TV shuts off after a few seconds.
When turned on, my Mitsubishi TV (Model #WD-62526) shuts itself off after a few seconds. The red light comes on and "lamp" is on. If powered on, the green light comes on, you can hear sound and see the screen start to lighten up, but then it abruptly shuts down after a few seconds and the red light comes on again. Does this mean that the lamp needs to be replaced or could there another problem? If the lamp needs to be replaced, is that difficult to do?
I sent a previous inquiry about this problem, but I had the wrong TV Model #.
  • 40 Answers
The lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Posted on Mar 13, 2009
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
WD-62526 shuts off
The power supply is failing. Your TV is able to start but the power supply can't continue operating and shuts down.
Dec 12, 2013 | Mitsubishi Televison & Video
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
I have a Mitsubishi tv model wd 62526 it makes a noise when I change channels and also when images change. Someone told me it could be the color wheel, also I do not have bright colors, I changed the...
This is an LCD projection tv- there is no color wheel, have your tv serviced- cleaned, hopefully you dont have optical block issues. contact a service shop.
Jan 14, 2011 | Mitsubishi WD-62526 Projection TV
I need a tv code for a mitsubishi tv model-wd 62526 2006
use your remote and press QV and 9 together. the reset the code
Dec 19, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62526
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62526 Projection TV Logo
1,113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
