Question about Home
NEED A WIRING DIGRAM TO CHANGE FROM 110V TO 220 V FOR SW12F1FDA00
  • 563 Answers
You would need a special transformer for that.
try RadioShack
Posted on Nov 15, 2009
  • 125 Answers
What is that?
Low voltage and hi voltage is just 220 and 110 can i still make the pump have two speeds
The 220v / 110v are the two wiring options on that motor. They usually come pre- wired for 220. The wiring can be changed to where it will run on 110. Be sure to get it right. if you wire a 110v motor to 220v it will go bang and die.
A two speed motor will have two hot wires, one common, and one ground (4 wires). Single speed will have three wires. You can't make a single speed motor a two speed motor.
Mar 01, 2015 | Pentair Pool & Spa
I have a WestPoint air conditioner, wsg series 12.2. The rooftop unit has a sticker that says 220v, but the inside unit (which is wired to the outside unit) is 110v. Is this 110 or 220? How do you
The inside unit is 110V. Now when you say wired to the outside unit you must be talking about the control wiring - not the high voltage wiring. Unless of course the outside unit is providing power to the inside unit.
You may need an electrician to wire it up for you -
Sep 26, 2014 | Heating & Cooling
Converting 220v to 110v
No, I'm sorry, but this is not possible. But remember that 220 vac is just two legs of 120vac cycled 60 degrees apart. So 220 may be available there. Talk to the local electricians--you may only need a new plug and recepticle installed, or it may take extra wiring, depending on the buildings wiring and local codes.
Mar 27, 2014 | Freezers
Convert 110volts angle grinder to 220 volts
change armature stator 220 volt
Jun 30, 2012 | Saws
I have a paragon timer model 4004-20 and do not have a wiring digram for it . can you help
http://waterheatertimer.org/Paragon-timers-and-manuals.html
I don't find the Paragon 4004-20 listed in manual.
4004-71 is shown, and uses wiring diagram 3
4004-71B, M, S use wiring diagram 4
4004-06 uses wiring diagram 7
Your timer sounds like a 240V DPST
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
Manual shows wiring diagrams, depending on how many screw terminals and loads you have, and voltage of clock motor and voltage of load.
Aug 21, 2010 | Paragon REPLACMENT MECHANISM 110V SPST -...
Wirng connecions for 110v pentair pool motor???
There shopuld be a diagram on the nameplate of the motor, or on the cover for the wiring compartment, or there is some stamped indication at the wiring lugs that tell you where to put your feed and what position the internal wires are to be in or the jumper .. for 110 volts or 220 volts.
May 29, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Dec 03, 2009 | Craftsman Saws
Ghart106 asked:
There is a wire diagram on the inside or outside of the motor housing. There is a simple wiring switch that you can do to change the motor from 110 to 220 or vice-versa. Everything you need to know is on the motor.
www.cpo2go.com
Sep 06, 2009 | Pentair 1.0 Hp Whisperflo Pump
Need to change wiring from 220V to 110V
Black or red is hot; green is ground; white is your neutral. The black should be for 120 and the red for 220.
Jun 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
WANT TO CHANGE FROM 110V TO 220 WOULD LIKE TO FIND WIRING DIAGRAM IF THERE IS ONE AVALABLE FOR ASW12F1FDA00
It's a lot of changes to convert the voltage.You know you got to buy new heating elements.contacter.Theonly going to save very little power bill.
Mar 13, 2009 | Home
Home Logo
71 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
