Question about Dryers
My dryer gets hot but takes forever to dry clothes i changed the vent hose but it still takes a long time to dry
    Scholar:
  • 124 Answers
Hi, Welcome. Here is your problem.
Two heat temp sensors in dryer. One tells heating element to turn off & on Like your house thermostat but it is set & not adjustable. (More than likely the one going out.) The other is temp Overload to prevent dryer from catching fire. It is recommended that you replace these as pairs.
Posted on Mar 13, 2009
  • 3 Answers
Inadequate airflow from the dryer to the outside is likely the culprit. The solution depends on the type of exhaust duct used - sheet metal, flexible aluminum that is fairly smooth or the good ol' white plastic duct.The best is the sheet metal duct work. The white plastic flex pipe is inexpensive, but creates more air drag causing the lint and dryer sheet residue in the air being exhausted to drop out and accumulate between the wire loops. If not suspended properly, severe sagging can literally cut off airflow as the result of the deposits. If a dryer blows its thermal fuse, heating elements are burning out faster than normal (some heating elements never burn out!) or you notice that the clothes seem waaay more hot than you recall, blocked or restricted duct work is the most likely causwe.
The dryer is heating up but takes forever to dry clothes
first things first, check the vent. if the unit isnt vented properly or vent hose isn't clear, it will take forever to dry. if the vent is clear, check the vent thermostat.
Mar 21, 2011 | Dryers
My dryer will heat up, but it is not drying the clothes during the cycle. It takes 2 or 2.5 cycles to dry the load
if you have the top model lint filter take it out put your hand in and see if you have good air sucken,if not you have a clogg somewhere in the dryer hose or wall vent,most of the time it is the wall vent, if the hot wet air can't get out the cloths will take forever to dry-mike
Feb 06, 2010 | Kenmore Dryers
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Our dryer gets hot how ever it takes forever to dry a load of clothes and it makes a huge thumping noise; what could this possibly be.
the thumping is the drum not moving around right you need to change the felt the vent hose must be tight and stright up and out no slack moister needs to be blown out
Feb 18, 2009 | Dryers
Dryer not heating
THE PROBLEM IS YOUR WALL VENT CLOGGED OR THE BACK OF THE DRYER VENT HOLE IS CLOGGED,IT KEEPS THE MOIST HOT AIR IN THE DRYER SO YOUR CLOTHS TAKE FOREVER TO DRY,THEY MUST BE CLEARED FOR THE DRYER TO WORK AGAIN-MIKE
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer takes a long time to dry.
This sounds like the vent is plugged up. The dryer gets rid of moisture through the dryer vent and hose. When this gets plugged up it will take a long time to dry or the hi limit will shut it off. When the dryer vent or hose is partialy blocked it will take vary tong times to dry the clothes and will eventualy cause the dryer to stop drying all together.
Nov 14, 2008 | Dryers
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 | Dryers
Dryer still gets warm but not as hot as it used to. Takes forever to dry clothes. Clothes used to come out really warm yo hot and dry butno more.
sounds like an airflow problem. disconnect the vent behind the machine and clean it out thoroughly. it might be kinked behind the machine, be careful when you push it back to the wall as to not kink the vent hose. if possible use a straight smooth metal duct to exhaust the air to the outside of your home.
Mar 10, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Dryers Logo
1,524 people viewed this question
Top Dryers Experts
