Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23429
Sides of freezer extremely hot
I have two problems: the freezer motor doesn't seem to be cutting off. Both sides of the freezer are very hot. And, the door is not completely shutting at the top of the freezer. Can the problems with the door not shutting properly be due to the freezer is not quite sitting level, and if so, would leveling the freezer fix my door not shutting properly at the top?
  • 3 more comments
  • Anonymous May 21, 2008
    sides of freezer is very hot
  • barmill Aug 01, 2008
    new comperssr now out side walls and top hot to the toch is this norm?
  • lpbaldwindri Aug 26, 2008
    alarm on freezer going off .sides of freezer hot compressor hot it is still freezing ,not too cold
  • garyfrance Sep 01, 2008
    GE Freezer, 6 years old, sides very hot and food inside starting to thaw. Moter running constintly but seal seem OK. Model FUF20DMDRWH.
  • csparer May 11, 2010
    I have the same problem (door not sealing) and I solved it with a child lock. Even with the door sealed the motor runs all the time. Can it be some thing else?
    Novelist:
  • 159 Answers
If there is air getting into the freezer because the door is not sealing properly the unit will run because it is sensing it is not cold enough inside. your unit releses the heat from the refrigerant through copper tubing that runs through the cabinet, and thats why it is hot. you need to level the unit make sure the door is sealing on the top bottom and both sides ansd then the freezer will work properly and be able to shut off after it has come down to the proper temp.
Posted on Aug 07, 2007
    New Friend:
Ok sides of stand up deep freezer super hot, .. so hot that it starts to defrost the interior... it is a Crosley and is almost a year old.. had repair guy out and he is stumped along with all his tech support.. why is it defrosting... before ya say fan, there is no fan, it is also a manual defrost and no coils other than those that run through freezer that ya can see when door open....there is pretty much one part on this,, the compressor.. so need to know how it should be fixed.. if the guys that learned this trade cant figure it out
Posted on Jun 22, 2013
SOURCE:
Hot side panels
Hello Robert - From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around the refrigerator. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can download one at the manufacturer site. If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your refrigerator) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachement and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath refrigerator. Cleaning condenser coils typically resolves this issue. But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Apr 24, 2013 | Frigidaire 13 cu. ft. / 368 liter Chest...
Why does it get very hot around the door's perimeter?
The door is heated so it doesn't stick shut with ice. It may be that the condenser is clogged or the fan isn't running, causing excessive heat in the strip. Clean the condenser thoroughly and check the fan.
Jul 01, 2012 | Kenmore Elite Side By Side Refrigerator -...
The outside of the freezer sides are extremely hot to the touch? Why? Freezing fine on the inside.
the coil normally on b ack of fridges is on sides of freezers under skin it is normal to be warm. The hotter the weather the hotter the skin.
Sep 02, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I defrosted the unit when I went to plug it back in the sides and front got extremely hot
1.It's a dirty condenser - clean it with soft vacuum brush
2.If it's clean - check condenser fan motor-it's located behind or before condenser - it should running.
Jun 29, 2010 | Whirlpool Freezers
The freezer is hot on the outside
Make sure the evaporator coils on the back or underneath near the compressor are clean. If there is a fan near the coils make sure it's running.
Dec 09, 2009 | Whirlpool 14.8 cu. ft. Chest Freezer...
Nor-Lake t3000 freezer - door HOT
The door frame heater is probably damaged and grounded. Unfortunately, it is still energized causing less than the entire heater being utilized which will cause an extremely hot condition. I would look at replacing it. It is a pain to do but with some patience, it can be done.
Good luck and hope this helps.
Mar 27, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Fridge freezer upright
Replaced the thermostat
Jun 22, 2008 | Freezers
Kenmore Chest Freezer
Believe it or not, but it is normal. Especially when just turned on. As the internal temp. gets colder so will the temp. on the side get cooler.
Apr 20, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23429 Logo
1,889 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
