Question about Frigidaire FRS26R4A Side by Side Refrigerator
FRIGIDAIRE SIDE BY SIDE WATER LEAKING FROM BOTTOM OF FREEZER DOOR
WATER LEAKS FROM THE FREEZER DOOR ON EACH SIDE
YOU CAN OPEN THE FREEZER DOOR AND SEE WHERE THE
WATER IS COMING FROM THERE IS ICE FROZEN ON THE BOTTOM OF THE INSIDE OF THE FREEZER WHERE IT SLOPES
DOWN TOWARD THE DOOR WHY DO I HAVE WATER ON THE
INSIDE OF THE FREEZER ?
  • taplia Mar 15, 2009
    same
    Guru:
  • 462 Answers
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
First lets decide where your leak actually is.
Areas to consider:
This is mostlikely a stopped up drain pan. A cold area that is not suppose to be cold likewhen you have a freezer coil that is suppose to be defrosting and is not... Seebelow for a more complete ideas list of things to check under Possibility.
The drain pan drain line is themost common. Inspect it and repair as needed, maybe its just a wrapper over the exit hole of the pan.
Some more Possibility's:
1 There is a drain that carries away the water under the cooling coils. Thesecoils are in the freezer section. Its most likely clogged or froze up.
2 The ice maker could be letting water leak all the way down look for an icy trail from the ice maker area.
3 Door gaskets are not sealing especially on the bottom of the door. Thisallows warmer air into the fridge section and it is condensation on floor underthe crisper.
If you check all of these items and still cant find it please post back andtell me what you did find. So I can help you more. Please rate me as much aspossible as Im trying to keep my average up and do the things that willactually educate and help people.
THANK you for using fixya and good luck..
Posted on Mar 22, 2009
FRS26KF6EMB
The water valve sounds like it may be leaking and the drain hole is plugged if this is a side by side the drain is in the very bottom back. sounds like it is actually a two problem situation you have. watervalve bottom back outside frige and drain in the back bottom of freezer.
Sep 23, 2012 | Frigidaire PLHS267ZA Side by Side...
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Water is leaking out the bottom of door
clogged defrost drain. remove ice from bottom of freezer and take very hot water and work back and forth with a turkey basteruntil water drains. blow out with hose.
Jul 25, 2009 | Frigidaire FRS23R4A Side by Side...
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Water leaking
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezerr.
Dec 27, 2008 | Frigidaire FRS26R4A Side by Side...
Water leaking from freezer door and ice maker not gettin water
Check the fill tube for the ice maker and make sure it is in the correct place. This sounds like the fill tube has been moved and is running water into the freezer instead of the ice maker. Let me know what you find. I am here to help you.
Nov 12, 2008 | Frigidaire FRS266ZDSB Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Oct 19, 2007 | Kenmore 57029 Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
484 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
