Question about Kenmore Microwave Ovens
Model 721.80032700 Number buttons on microwave stopped working. What is the problem?
3 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave stopped working for no reason
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your tech sheet, you can download it here.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download Whirlpool owner's manuals and installation instructions here.
Posted on Nov 23, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: microwave model number: 721.80593402.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still doesn't work, then your membrane keypad has failed.
If the keypad is available separately and
you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If this model's keypad is not available separately, you would need to order the control panel frame, which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Posted on Feb 17, 2011
Ge microwave jvm1740 start and clear/off button not working
Sounds like a bad keypad. You will need the full model number off the microwave to look up the correct control panel part number. Sometimes these type of parts can be really expensive & it may make more sense to replace the microwave depending on the age and condition.
Sep 05, 2014 | GE Spacemaker JVM1740 Microwave Oven
Buttons make numbers appear on screen
The keypad control board must be replaced in order to address the issue, but keep in mind the part alone is expensive.
Apr 18, 2012 | Microwave Ovens
We have an older Radarange over-stove microwave oven with touch pad controls. Whenever I boil something without a lid for a longer period, some of the buttons stop working. Usually, they begin working...
Call Amana customer service. Microwave ovens should be able to handle the high humidity you are talking about.
Here's the contact information:
Have your complete model number ready. You can find your model number and serial number on the label located on the upper or lower
front facing of the microwave oven opening, behind the door.
For assistance or service, call 1-800-843-0304.
If you need further assistance, you can write to Amana with any questions or concerns at:
Amana Brand Home Appliances
Customer eXperience Center
553 Benson Road
Benton Harbor, MI 49022-2692
Aug 05, 2009 | Amana Radarange Microwave Oven
All the buttons on the appliance won't work except for one
sounds like a bad key panel i think if you replace it will be ok
Jul 24, 2009 | GE JES1231 Microwave Oven
Unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Jan 06, 2009 | Sharp R-308J Microwave Oven
Some of my Buttons don't work on my microwave
Chances are your keypad has failed.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If yours is not found there, please reply back with your brand and model.
If you don;t prefer to repair it yourself we can help.
Jan 22, 2008 | Microwave Ovens
Microwave Ovens Logo
101 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
