Question about Toys
Bobcat fuel shut off solenoid getting hot
During operation, solenoid gets so hot you can't touch it.
2 Suggested Answers
  • 32 Answers
SOURCE: I have a 2005 Bobcat t190 with an error code 14-03
Try switching relay for fuel solenoid make sure all fuses are good. Fuel solenoid could have internal short in one coil. Replace solenoid and relay
Posted on Nov 17, 2012
I have a 08 bobcat 463 with a Kubota engine. it will not start I checked fuel shut off solenoid its good cracked lines at injectors have fuel. sound like it wants to start lot of black smoke
That black smoke is because it isn't getting any air to mix with the fuel your putting in it. Your air cleaner is either plugged up completely or there is a emergency shut of flap on the intake that needs opened.
Jun 25, 2017 | Cars & Trucks
Where does the wire to the solenoidon on the carburetor go to?
ignition switch
Those wires are for the fuel shut-off solenoid.It shuts off fuel flow to the main jet,when the key is turned off.One wire will go to the wire that is hot,both on cranking,and running positions.Check it with a voltmeter,to find out which wire it is.The other wire,is a ground wire. You want power to the hot side,during crank over,and running,but not on the off position .If it's not hooked up,the carb won't get fuel. Small Engine Repair How to Check Solenoid Fuel Shut Off Valve on Kohler...
Jan 17, 2016 | Garden
I have an 863 bobcat, I shut it off for just a few min, then when I tried to start it back up it turns over but won't start, I tried starter fluid which will start it but it will only run for a few seconds
I presuming it is a diesel bobcat, if so then your fuel solenoid has failed, you will need to replace the solenoid, it a large nut with a wire coming from it and it's located on the fuel injection pump,
Jul 24, 2014 | Cars & Trucks
My 1993 compact bobcat skidsteer won't start, it just stopped running and won't start, I have tried starting fluid and still nothing?
Could be engine speed sensor. All fuses need to be checked. Any smoke when cranking? Any fault codes? A bad fuel solenoid could cause no start if fuel is good.
Sep 09, 2012 | RTO Construction Bobcat by Woody Click
My Briggs and Stratton powered (17.5hp Intek model 311777) Troy Bilt riding mower idled down slowly and died. It was a very hot day after about an hour of mowing. I don't appear to be getting an
Hi, armature is for spark and you stator is only for charging the battery. Check for spark again after disconnecting the single small wire from the armature incase its a safety switch issue, regards Phil.
Jun 06, 2012 | Garden
I have a 250 bobcat that stick welds just fine but when you go to wire feed and plug in suitcase box wire feed unit wire feeds but it doesn't get hot enough to melt the wire. LF299725
What model of suitcase? Could be the contactor in the suitcase, could be the mig gun. Are you using the CV setting on the Bobcat, instead of CC? Is the Bobcat on the high CV setting and the dial most of the way?
Apr 30, 2012 | Miller Bobcat 3 Phase Welder Generator...
I have a 2005 Bobcat t190 with an error code 14-03 Fuel Shutoff pull solenoid error OFF
Apr 26, 2010 | Garden
Toys Logo
52 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
