Question about MSI 845GVM-V (MS-7057-010) Motherboard
Memory does not compatible with the board.
I had two 256 memorys. one is pc 2100 133 and the other is pc 3200 200MHz. After upgrading to PC 2700 333Mhz, pc does not boot it and repeat memory test continually. Also memory test shows only 32145k. Please help me to upgrade for it
  • MSI Master
  • 12,061 Answers
Hi, it is unadviseable to "Mix" R, or more,am's .. they MUST be exactly the same generally to work together. IE: generall ANY two PC2100 would be OK, ANY two, or more, PC3200 would be OK. BUT NOT MIXED.. It really is as simple as that. Sometimes RAM's of differing types can Be OK... but most often it's causes problems. You need them ALL to be PC2700 333MHz.
Posted on Aug 05, 2007
SOURCE:
I'm looking to upgrade the RAM in my father-in-law's computer (Compaq Presario SR1500NX desktop). All the "see what ram you need" searches on various websites that sell memory indicate PC2700 is...
This is the memory specs for the SR1500.
Presario SR1500NX Memory Specifications Standard Memory 256 MB (removable) Maximum Memory 2 GB Memory Expansion 2 sockets Memory Comments PC2700 DDR SDRAM DIMMs. CPU Type 2.0GHz AMD Sempron 3000+ Model Comments 333MHz FSB, VIA KM400A Chipset.
The PC2700 refers to the RAM speed, so you can use PC3200 which is faster RAM than PC2700, the PC3200 RAM should be more expensive not cheaper unless this supplier has stock he needs to unload.
You will not get any speed performance with the PC3200 RAM because the motherboard cannot make use of this faster RAM.
Dec 03, 2010 | HP Compaq Presario SR1500NX (PX786AA) PC...
Compaq Presario 5LOXE1 Memory upgrade
So you mean only 1 video card is working and the other one is not?
May 04, 2008 | Compaq Presario 5000 PC Desktop
Memory Upgrade Problems with Toshiba Satellite 1415-s173. Upgraded memory from 256 x 1 pc 2100 (original samsung came with laptop) to 256 x 2 - (Hynix pc 2700) which is the max for this model. Did go from...
Without a bios update and updated operating system the ram may not work properly.Also the memory itself may be faulty.Verification of compatibility doesn't really guarantee the ram will actually work properly when seated.You should have used 2 pc2100 ram sticks.
May 06, 2010 | Toshiba Satellite 1415-S173 Notebook
I want to upgrade my RAM on my eMachine t3504. I currently have 256 in each of my 2 slots. Can I upgrade one of the slots to 1 GB and leave the 2nd at 256 or do I have to upgrade both slots?
Yes you can upgrade 1 of the slots to 1GB, as long as 1GB stick of memory is the 256MB stick then you can have both, to check the memory you will have pull them out of the slots and have a look on a little sticker on one side of them. You are looking for i.e DDR400/333/266 if the 1GIG memory matches one of the values mentioned above, say it is a DDR400 and the 256 is a DDR400 then they are compatable if not you will have to just leave the 1GIG stick in by it self in DIMM socket 1.
Apr 03, 2010 | E-Machines T3504 PC Desktop
Sir,i would like to upgrade my memory(256MB DDR2)for acer travelmate 4061nwlci pls inform if 1GB is compatible.pls help
Your System memory is upgradeable:
256 or 512 MB fitted as standard upgradeable to 1 GB of DDR2 533 memory, or 2 GB using two soDIMM modules.
Regards,
Mike.
Feb 23, 2009 | Acer Computers & Internet
Memory question
Each memory contain chipset , with black block coloured, each of this chipset has the ability of error parity checking, and own their clock latency, KVR is the kingston chipset , 100 stand for the clock or memory clock, PC 100 is means that the memory is SDRAM, While the DDRAM stands for 266(PC 2100) , 333 (PC 2700) . and the other x64 means this memory support 64 bit data flows, cl2 means clock latency (the delay for the memory to write and read), and 256 is the real size of the memory module.
Aug 01, 2008 | ASUS Intel 440BX Chipset P2B-S Motherboard
Ram upgrade
http://www.bestbuy.com/site/olspage.jsp?skuId=7333218&type=product&id=1118845304999
Above is a site showing some of the type of memory that you need. The memory type is 333 Mhz PC 2700 SoDIMM memory. Installation would cost $39 at Geek Squad.
Apr 14, 2008 | Toshiba Satellite A60 Notebook
Dell dimension 3000 memory card
if your pc is old, it may not be compatible with that amount of memory.. check to see your are buying the correct type of memory, a lot of pc's vary depending on model.. be sure to push down firmly when installing the memory stick.. hope this helps
Feb 21, 2008 | Dell Dimension 3000 PC Desktop
Joey64,. pno ko nman mla2man kung ang anu clock speed ng pc ko? tska kung anu compatible na memory and videocard. P3 733 is my pc.
733 is the processor. thats determining the speed of your system. compatible memory is SDRAM 256 mb, AGP video card geforce 1-4.
sana ok na sayo.
bakit di ka mag upgrade ng PC. marami namang mura dyan 16T ok na.
Jan 10, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Memory upgrade
you can use any DDR 180pin. But having two RAM of different speeds may not be compatible sometimes, so upgrade it to 1Gb by just using (1) 1Gb pc3200.
May 15, 2007 | EliteGroup P4VMM2 Motherboard
MSI 845GVM-V (MS-7057-010) Motherboard Logo
69 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
