Question about Snapper Garden
Snapper sr930 The deck of my mower is too low. I can't get it high enough to cut. Any suggestions?
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 218 Answers
SOURCE: one blade on deck gives an uneven cut
Hi..my name is Keith..and most times..when your problem happens..either the deck is bent down from runing into something or stepping on it..or the deck hanger is bent, worn or out of adjustment..or the blade on that side is bent..and i hope this will help..if not..please write back
Posted on Jul 04, 2009
wadembly
  • 448 Answers
SOURCE: How to replace lower deck spindle bearing on my
take the deck off or take the belt off of pulley there is a nut on top of pulley loosen nut with a brass hammer hammer it down & it should drop the spindle out to replace bearings
Posted on Jul 09, 2009
  • 41 Answers
SOURCE: mower will not move while in gear
check to see if there is a second belt for the transmission, you may have nicked that belt or put the pulley tession to the wrong bulley.
Posted on Jul 15, 2009
mowerman1857
  • 389 Answers
SOURCE: how to adjust the mower deck on my murray rider,
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
Posted on Oct 11, 2009
Mower deck belt routing diagram for snapper mower model YT16D414B
Request the mower deck belt routing diagram directly from Snapper.
Jul 09, 2017 | Snapper Garden
Briggs stratten 8HP on snapper Sr930 won't stay
Could be a dirty carb or fuel jet.
Sep 25, 2014 | Garden
Why does my zero turn mower struggle when trying to cut grass, it seems to be using half power.
If is a twin cylinder engine this could be very well the problem. Without the engine info it is hard what it could be.
Jul 23, 2014 | Craftsman 42 in. Precision Cut Plus 24hp...
I have a craftsman lawn mower that will not cut even. I have replaced the spindles but that did not do any good. Any suggestions? It is a model 917.274031 with a 42 inch cut.
On a clean lever surface, raise the deck as high as it will go. With the motor OFF, look under the deck. One of the blade tips will be lower than the others. That will be the source of the problem.
If you hit something with the deck, the deck itsself may be bent, or the blade may be bent. If everything is really worn, the assembly holding the deck up may be worn on one side, causing it to sag on that side, but this should be visible to the naked eye.
Feb 21, 2014 | Briggs 20 & Stratton Toro Craftsman...
Snapper sr930
I wound go to Sears Direct
May 18, 2013 | Craftsman Garden
Won't cut on low height setting
there are several rods that support the deck if one is missing it can allow the deck to move in the wrong dirrection
May 22, 2012 | Garden
Garden Logo
91 people viewed this question
Top Snapper Garden Experts
ray gallant
solver2010
Thomas Perkins
Thomas Perkins
Are you a Snapper Garden Expert? Answer questions, earn points and help others
