Question about Kawasaki Engines NEW 19 HP KAWASAKI ENGINE FH580V-DS29-S REPLACE KOHLER BRIGGS ZERO TUR
Mower loosing power
Kawasaki 19 hp engine on Bob Cat 0 turn mower. Loses power going up hill. Have replaced plugs, air filter, and fuel filter, cleaned gas tanks and new gas. Any suggestions
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
My mower has a fh451v 15 horse Kawasaki engine and it runs funny when i put the air filter on it and its new ???
Any way you could try a filter that lets in more air? On some mowers, the long threaded bolt that holds the air filter on will actually go into the carb. Maybe it is too long?
May 25, 2015 | kawasaki Garden
My john deere 316 loses power going up hills and when I have the mower pot on
Sounds very much like a fuel issue, i.e., starving for fuel. Check the fuel filter and replace.
Aug 04, 2014 | John Deere 300 / 316 Hydrostatic Tractors...
Kawasaki 19 hp not getting gas
This engine will probably have an in line filter and a black plstic fuel pump bplted to the side of the engine, rplace the in line filter first, if no better pull the fuel hose off the carb and crank the engine, there should be a staedy flow of fuel, if not check the pipe connections on the pump are good ( it is a vacume pump, it taks a pulse from the engine to work a diaphram ) if connections are good and no fuel flow, replace the pump, there will also be an anti fire solinoid on the bottom of the carb, to check this component remove , switch the ignition on, the jet inside should sink into the housing.
Jul 07, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
19 hp kawasaki mower motor that dies after operating 45 minutes
well its back to the fule flow,,,i thing the fule lines and carb are blocked up and needs a strip down and a good clean up of all the jets and flote bole this sounds like fule shortage,,,if the engine is only just turning and you try to put it in gear so the cutters start to turn it loads the engine up and it stops!
you say pulling the choke out get it going!!!!! then its short of fule ,,,right!
Jul 15, 2010 | kawasaki Garden
Engine dies when Blade is engaged
It sounds like the seat safety switch is the problem. Tilt up the seat and make sure the plug to the seat switch isn't loose or off completely, and that the switch is firmly mounted. If everything seems ok, remove the switch and test it with a multimeter. The circuit between the switch terminals should close when you press in the button. If not, replace it. Good luck!
Jun 04, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Lack of power
Yes FUEL, the Motor is NOT getting enough. Things to check, Gas, Float valve, float bowl, Mixture, Spark Plug, Spark Plug Lead, & ends. Check for any clogged fuel filters.
www.m-and-d.com/helpfaq.html
www.ehow.com/how_6129297_troubleshoot-husqvarna-mower-kawasaki-engine.html - United State
http://outdoorpowerinfo.com/repairs/
OK links above will assist in fixing your problems.
Apr 15, 2010 | John Deere 420,1020,2010,2020,2510,2520...
19 hp kawasaki carb acting up
sounds like the carb is gummed up from the old gas you will need to clean and rebuild te carb(this is a easy job)...good luck
Apr 04, 2010 | Garden
15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
Apr 20, 2008 | Black & Decker 19" Electric Lawnhog...
Open Questions:
Kawasaki Engines NEW 19 HP KAWASAKI ENGINE FH580V-DS29-S REPLACE KOHLER BRIGGS ZERO TUR Logo
Top Kawasaki Engines Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Kawasaki Engines Garden Expert? Answer questions, earn points and help others
