Question about Garden
How to replace the Front wheel of Craftsman 190cc 22inch Front Drive EZ Lawn Mower
Model# 917.376402
  • 4 Answers
SOURCE: The front wheels on my lawn mower have locked
I had this same issue. In my case, the sheild that keeps the dirt out of the gears in the wheel has gotten broke and the gears filled with junk and jammed the wheels. I just have to take the wheels off and blow the junk off the gears.
Posted on Jun 07, 2009
  • 78 Answers
SOURCE: honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
Posted on Oct 27, 2009
  • 89 Answers
SOURCE: craftsman lawn mower wheels won't turn
take cover off the top off deck and see if your belt have came off next turn deck sideways but before you turn it sideways take air filter off cause oil can come through and ruin the filter noe look and make sure the belt is on the pully
Posted on Nov 04, 2009
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
rycgl
  • 1545 Answers
SOURCE: where is the carburetor on
The carburetor would be located BEHIND the air filter housing and air inlet tube. The air filter housing should have a removable (by screw or clip) cover.
Posted on Apr 13, 2011
How to remove drive wheels
Although I'm not familiar with this model, on some, you remove the center hub cap, and remove the bolt underneath. The wheel should slide right off.
Jun 23, 2015 | Craftsman 675 Series 190cc 22" Briggs ...
Front wheels lock up when mower pulled backwards
Not uncommon for the drive to turn in only one direction.
What do I need to do next if the tension is gone on my craftsman self-propelled lawnmower.
The cable will need to be replaced. They tend to rust and become broken. The function of the cable is, it opens the kill switch and releases the engine break. Hopes this will help ya.
Jul 19, 2014 | Craftsman 190cc* 22" Front Drive...
Rpoe wont pull
Either something is blocking the blade and preventing it from turning or your engine has seized.
Apr 17, 2013 | Craftsman 190cc* 22" Front Drive...
How to replace drive cable on craftsman platinum 700cc mower
I have to change the drive cable I have the end on the handle but cant figure out how to do it on the mower head
Oct 01, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
The front drive self propelled wheels stick and squeal
why is the back wheels of my briggs stratton wont stop turning
Aug 29, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
PP 22inch 625 series 190cc - What Gas/Oil mix should i be using?
I think your mower has a 4 cycle engine. That means the oil goes in the crankcase and the gas goes in the gas tank. No oil mixing needed! If you look at the top of the mower you should see two caps. Each one will be marked with what goes in them.
The oil should be 30 weight non-detergent oil. Available at your local car parts store or Lowes or Home Depot.
Gas is just plain old pump regular.
Oct 09, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
