Question about Durabrand DU1901 TV
Need a picture tube
I have no picture anyone know where I can get one
    Problem Solver:
  • 19 Answers
You have to show you tube size,frat screen?its very important.
Posted on Nov 02, 2007
SOURCE:
Have sound, but no picture
You do not need a "picture tube" whatever you may mean by this.
Here's what you need:
(sorry, no point in copying it, so referring to it instead):
http://blog.coppelltvrepair.com/2011/02/hp-pl4260n-suddenly-lost-picture-how-to.html
Feb 16, 2013 | HP PL4260N 42 in. Plasma HDTV
Orange tint too screen
To know what is wrong do a simple test almost anyone can do
Model listed has three picture tubes, with rear cover removed turn set on and look into the three lens, each should have a picture--one red, one green and one blue.
If any one of the three look like a floodlight you have bad glycol in that tube.
This will not be a do it yourself repair, The liquid is toxic and like antifreeze to keep the face of each tube cool.
Do not attempt to take the lens of the affected tube apart, that can be fatal to you and the set.
Let me know what you find and I can give you options.
Dec 13, 2012 | Philips Magnavox 9P6034C 60" Rear...
I have a rca tv model #27v5137 that only has the bottom picture displayed. Does anyone know what is wrong with the tube?
It is not the picture tube but is a vertical deflection problem. Usually it is a capacitor C246 and this is the location number and is a .47mf And at the same token bad solder connections on the pins of the vertical deflection IC301. Soldering the pins of IC301 is likely to fix the set.
May 18, 2011 | Televison & Video
No picture available.
for plasma tv's there is no picture tube, it has only electron gun .it will be cost more at the same time buying a new one.
Jun 12, 2010 | LG 42PB4D 42 in. Plasma HDTV
How do you clean a vs5046 projection tv it has a dark picture or does anyone know where to download the manual production date feb 1997 serial #007286
This TV is probably finished. The picture tubes don't normally last more than 8 or so years with normal use. The back cover is easy to remove on most projos (power OFF!!). The picture tubes can be cleaned with a damp cloth like a chamois. Don't handle the mirror. The silver is on the wiping side - you will destroy it! Stay out of the electronics! Safety hazard.
Mar 21, 2010 | Televison & Video
Still Need Some Help
SOny has had big problem with BAD picture tubes so when tube begins to short in return it will burn flyback transfomer ,shorting out hori output.I know i thru away better then 50 sonys all with same problem. some of them where only a year old!
Jul 18, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Neon in color
sounds like you might need a good cleaning or your tv has contaminated coolant in the picture tubes. or you just might need to adjust the screen control for the picture tubes.
Feb 20, 2008 | RCA P46924 46" Rear Projection Television
Toshiba 32A41 TV -- color problem
Toshibas are notorious for developing shorts in the inernal guns of the picture tube. In your case the green gun is shorted to G1. The noise you heard was an internal arc between the elements. It is unfortunate however, the repair of this problem usually requires the picture tube to be replaced. Sometimes a savvy technician with sencore picture tube rejuvenator can remove the short. This however usually does not last. Scrivitron
Jun 16, 2007 | Toshiba 32A41 32" TV
Problem with the color on my Zenith
picture tube need a picture tube reguvinator $1300
Apr 29, 2007 | Zenith C27A24T 27" TV
Tube sparks inside itself under red projector??
have a tech check your set high voltage is escaping.good luck.
Apr 15, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Televison & Video Logo
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
