Question about Radio Communications
President washington base cb diagram - Radio Communications
  • 1274 Answers
SOURCE: i have a president zachary t base station cb radio
Hi coonhunter,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
Could I ask you to re-post, your question falls under something
different. I have BASE is that correct?
Posted on Jan 02, 2011
Benimur
  • 6966 Answers
SOURCE: John Q president cb
If by calibration, you are referring to the check if your antenna is tuned, below information may be of help.
S/RF/SWR/CAL SWITCH. When in the S/RF position, the meter swings
proportionally to the strength of the received signal. When transmitting,
the meter indicates relative RF output power.
When in the "CAL" position, the SWR meter can be calibrated by adjusting
the "SWR CAL" control to the "CAL" mark on the meter face.
When in the "SWR" position, the standing wave ratio is measured.
SWR METER. Measures standing wave ratio of the antenna system.
Used to properly adjust the length of the antenna and to monitor the
quality of the coaxial cable and all RF electrical connections. If there is any
degradation whatsoever in any of the foregoing, due to humidity, salt
spray, vibration or corrosion, the SWR meter reading will rise, thereby
indicating that a problem exists.
To calibrate, switch to the "CAL" position, transmit by pressing the mike
switch, and adjust the SWR control to the "CAL" mark on the meter; then
switch to "SWR" position for the SWR measurement.
If however you are referring to the internal calibration or tuning of the transmit and receive sections, you would need several instruments/equipment such as RF generator (0-30Mhz with 1Khx modulation), Spectrum Analyzer, Modulation Scope, Dummy Loaded Wattmeter, Frequency Meter and some others. These of course are not readily available to the average user.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 02, 2008
SOURCE: cb mic wiring
I have a browning golden eagle mark II. It has a two pin mic plug. I would like to hook up a astatic power mic to it. Anyone have an answer?
Posted on Jan 24, 2009
  • 39 Answers
SOURCE: explaihow to wire a turner +3 mic to a president washington base
Here you go 1/shield 2/white 3/black 4/red . Good luck......Dan
Posted on May 06, 2009
  • 39 Answers
SOURCE: wireing turner plus 3 to president washington that is four pin
Wow I've never seen a six wire Turner + 3 anyway give this a try 1)shield & blue 2) white 3) black 4) red if the radio keys up as soon as you plug in the mic switch black and red . Good luck . Dan
Posted on Jul 27, 2009
Wire 4 pin Turner Plus 3 Power Mic for cb radio to 5 pin President Washington SSB AM Radio
the best i can find is this
red pin 5 ptt
black pin 4 ptt ground
white pin 1 mic
shield pin 2 mic ground
no connection pic 3
Jan 19, 2015 | Radio Communications
Cb radio wiring diagrams
This light is not a field-replaceable item. It is wired-in, so you will need a small, low-wattage soldering iron and some solder-wick plus a little know-how to remove the dead lamp. Next you will need a replacement lamp. That's a fairly old CB radio, from the late 1970s, so you may have trouble finding the correct light bulb. I'd recommend taking the old one with you & go so somewhere like Radio Shack to see if they have something similar with wire leads on it. Otherwise Google for it. Good luck
Jun 18, 2014 | Radio Communications
Service manual base uniden washington
google it. president wash serv manual.
May 14, 2014 | Uniden Radio Communications
Tune president washington cb radio
please re-post this question with accurate description of problem.
Feb 17, 2010 | Uniden Radio Communications
Wireing turner plus 3 to president washington that is four pin
Jul 23, 2009 | Magnum DeltaForce CB Radio
Mic wireing
For a Turner +3 it is 1/shield 2/white 3/black 4/red.For an Astatic 4 wire it's as follows 1/shield 2/white 3/red 4/black ; for a 6 wire it is 1/shield&blue 2/white 3/red 4/black - yellow no connection . Good luck....Dan
May 01, 2009 | Magnum DeltaForce CB Radio
Explaihow to wire a turner +3 mic to a president washington base
Apr 28, 2009 | Magnum DeltaForce CB Radio
Uniden washington base station
I need the wireing information for uniden washington CB radio,thank you.
Oct 28, 2008 | Uniden PC78ELITE 40-Channels Base CB Radio
Radio Communications Logo
32 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
