Question about Canon Office Equipment & Supplies
Cannon Pixma MG2100 Printer - After Paper Jam Not Working
Hi, Had paper jam and pulled paper out from back. Then the printer would nor work. New black ink added recently. The black ink light is on and it is flashing 'P' with orange triangle to the left of it? Have paper in the tray. Any ideas on how to fix, or reset?
JohnSc
  • 21 Answers
SOURCE: Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
Posted on Feb 11, 2008
pankaj_dic
  • 1250 Answers
SOURCE: Canon Pixma iP1600 Printer problem
this is the service error download canon chip resetter utility, then reset your printer , download IP resetter utility
Posted on Nov 14, 2008
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
  • 58 Answers
SOURCE: canon pixma ip1980 service error 6000.. it flashes
you need to open the printer. it has sensors around it. the one that you need to check is in the left side when you are facing the printer. the one that is sensing the graduated circular part. Remove the left cover on the side. then remove the sensor with a philip screw driver and clean it. then place it back and turn your printer on. I hope to be of help to you. Let me know if this works. I did it on mine.
Posted on Aug 13, 2010
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
Paper jam in Cannon Printer
open top if you can do it if you can not softly pull paper if still does ask person at store and if STILL! not work return it.
Jun 20, 2013 | Office Equipment & Supplies
I have a cannon Pixma Mp495. THis morning some paper that was wrinkled went through it when it was printing. THere was not any paper left in the printer. I did pull a sheet out the top that was stuck...
I believe that you tried to turn the printer off, then on. Did you? If so, and the problem persists, I belive that the jam sensor became damaged.
In a last instance, you can turn off the printer and see if you can turn a little (with your fingers) the roller that pulls the paper.
Jul 20, 2011 | Canon PIXMA MP495 InkJet Printer
My IP 5000 Cannon printer says I have a paper jam but
Under the circumstances go to control and click on printer. Clear all the printing jobs. Switch off the printer and the computer. Wait for sometime and restart the computer and the printer. This should clear your problem.
Dec 20, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Cannon ip 1800 printer
hi, your paper feeder might be jammed, try seeing if your little wheels turn properly (where the paper is fed) let me know..
Sep 10, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Under one year old pixma mp150 all in one/ changed ink cartridges/error code E2 / saying no paper ????
I have had a MP 150 Cannon Printer with a E3 paper jam code..when NO visable paper jam is present ! Your No paper problem may be as a result of similar issue due to a small piece of paper stuck in the roller assembly out of sight. TRY this, Turn printer off wait (10 seconds) or more then turn printer back ON and listen for roller assembly to turn the ROLLERS and then FORCE FEED
a sheet of paper into rollers until it PULLS paper through and SEE if any scrap of paper comes out with the sheet !! If this works you should see that it clears the code. and resets your printer.
Let me know if this works. Phil at palcando@yahoo.com
GOOD LUCK !
May 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have PIXMA MP 600 PRINTER that has a paper jam as I fed used paper back into it /ink was still wet and apparently paper has stuck together and jammed. How do I clear
clear the jam paper
1) pull slowlly the jam paper back as possible as you can, usually the jam paper could be broken as pulling
2) open the cartridge area find the paper pull slowlly forword paper direction as possible as you can and try to take out any pieces paper behide the cartridge (between paper input roller and ink cartridge
Jan 24, 2009 | Canon PIXMA MP600 all-In-One InkJet...
'Paper jam msg' when there's nothing stuck in there...???
Sorry can't help. Maybe you have damaged one of the paper jam sensors?
Try the link below which is the manual
http://alpha03.c-wss.com/inc/ApplServlet?SV=WWUCA900
Dec 29, 2007 | Canon PIXMA iP1600 Printer
355 people viewed this question
old marine
old marine
