Question about Mtd Garden
11a 020b029 the engine will fire up only when primed with the primer button but soon after shuts down as if its not getting any other fuel, what could the problem be?
5 Suggested Answers
  • 109 Answers
SOURCE: Mower will not stay running unless primer button
The tube in the bottom of the carb. is probably clogged. Remove the carb, and bowl and try spraying WD-40 through the tube, it should spray into the venturi if it doesn't try using a tip cleaner to unclog the tube.
Posted on Apr 16, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I Have a push lawm mower (mtd product model #
I really need your engine number but I am going to guess that it is a 3.5 to 4 HP Briggs & Stratton with a black primer bulb on the side of the carb.
Try this the next start. Take a screw driver handle just a bit smaller than the primer bulb and FORCE it against the carb body trying to make a seal with the primer rubber against the carb body. You use your thumb if you can manage to depress the entire area of the center of the primer bulb agains the carb body. If it runs normally when you do this..... the Primer Bulb has a pin hole in it. (No joy..... read on)
If after doing the above you strill have the same problem remove the air cleaner and tighten all of the screws that mount the carb to the gas tank. Often over time the carb body will warp and then it starts getting air introduced into the diaphram that is between the cab and the gas tank. Tighten the screws. There are usually 5 of them. (Remember the body is plastic.... tight but don't break it) Then try another start.
If that does not work the diaphram between the carb and gas tank is probably damaged and will need replaced.
If you need parts info respond with your engine number or go to www.briggsandstratton.com and look it up for yourself using your ENGINE TYPE MODEL SERIES number found on the air shroud above the spark plug.
Thanks for choosing FixYa.
Kelly
Posted on Sep 29, 2010
  • 6468 Answers
SOURCE: mastercraft 4hp sat along time cleaned carburator and installed kit... still wont start
threw jets if the carb was stored with old fuel the jets could be plugged up as well as the needle valve can be stuck
Posted on Jul 10, 2012
H2_Brad
  • 425 Answers
SOURCE: how to replace the fuel primer button on a Briggs & Straton 38 sprint motor
They are usually held in with either a small, round metal spring clip or a plastic one. A small dental type pick with an "L" shape at the end is often all you need to pry out the clip.
Posted on Aug 24, 2012
Will not prime with primer bulb , can squirt gas in carb and get running then while running you push the primer button it chokes down the engine .
Does it stay running after you squirt fuel in the carb opening? If yes, then there may be a pin hole leak in the hose going from the fuel tank to the primer bulb and it is adding air to your carb.
Thanks
May 01, 2015 | Craftsman 675 Torque 190cc 21" Briggs ...
My prime bulb looses pressure and first start is hard. I have to remove fuel line from filter and cover with thumb prime re install then first start takes time.
Does the engine run fine after it starts? Most common problem with primer bulb losing prime is an air leak in the fuel line or primer bulb. Air leaks don't always leak fuel. If there is an air leak between the primer bulb and gas tank there is no pressure, only vacuum. If it is not a major leak it might not leak without pressure but it will allow air to enter the fuel line. If it is a very minor air leak it could allow air to replace the liquid in the fuel line over time, but so little air once it is primer again that the fuel pump can over come it with volume of fuel.
Primer bulbs do not stay firm, as they are when initially pumped up, after the engine is running. There are check valves in the primer bulb that hold pressure in the primer bulb and throughout the fuel line to the engine. Once the engine starts the fuel pump creates vacuum drawing fuel into the engine diminishing this pressure and releasing the check valves. At this point the primer bulb is just another segment of fuel hose allowing fuel to pass through it as the fuel pump demands. The primer bulb functions much better when the outlet side is higher than the inlet side. This position makes it easier for the check valves in the primer bulb to seat and release as needed. If the primer bulb is functioning properly and is positioned with the outlet side higher than the inlet it should not be necessary to cover the end of the fuel hose with your thumb to get it to prime.
If the engine is hard to start after being fully primed there could be a problem with the fuel system on the engine. Some engines are hard to prime once air has entered the system, especially fuel injected models.
Dec 19, 2014 | Boating
I have a 2012 craftsman mdl 316.711970. I follow all maintenance requirements. It will only starts when the choke lever is in position 1. It takes forever to prime it cause the primer button doesnt pop...
I don't think so either. I think you have crud built up inside your fuel tank, and it needs to be thoroughly cleaned inside, Your carburetor may also need to be thoroughly cleaned inside.
Jul 29, 2014 | Garden
I have a CS4518 Earthquake chainsaw that will crank fine when you pump a little gas to the carb, but stops as soon as it burns the gas. I have replaced all fuel lines, primer bulb , cleaned the carb and...
Hi, OK firstly when you pump the primer bulb the primer bulb pulls fuel from the reservoir and pushes it to the carb then after around six to ten pumps the carb chamber is full and the fuel then goes back to the feservoir. Normally if you have a leak on the fuel line you get air in the priming bulb. Next thing is having primed Put the choke on full and pull the engine over a few times untill you hear it fire. Then depress the throttle and put the choke lever back to normal run position and pull the starter a couple of times untill it starts. Thats a pretty fool proff method on all two stroke machines and I have a few. Hope that is of some help.
Steve
Aug 28, 2013 | Garden
Engine on 30"Craftsman 2009 snow thrower won't prime. Primer button and connecting tube look good. Primer button won't send gas to the carb.
the priming bubble can look totally perfect, but all it takes is a pin hole and right around the retaining ring is hard to spot a crack and you should also check fuel lines in tank
Jan 07, 2013 | managemylife.com
My briggs and stratton 158cc 500series push mower primer button melted from sun. how do i replace it?
There is a tab on either side of the carburetor right where the primer bulb sits. You can depress both of these tabs with a screwdriver and pry out the plastic ring that holds the primer bulb in place. You can purchase a new primer bulb (with a new plastic tab) from a local mower shop or from a small engine repair shop. When you install the new primer bulb, put the rubber bulb in first then put the plastic ring on top and press it in until the tabs click on each side. It should work correctly after the tabs are clicked properly. You can take off the air filter and look into the carburetor to see if the unit is priming correctly. I hope this helps you out.
May 09, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Wont stay running without pushing primer
Hi... I have a Poulan PRO Quantum xnp 6.75. Garage kept, unused approximately 2 yrs. Added fuel, primed & mower started but then shut down immediately. Then fuel began leaking from the primer button. I'm a single mom & CANNOT afford to have anyone fix this. However I am attempting to repair myself. PLEASE.... If you have any suggestions &/or solutions I would LOVE to know.
Apr 12, 2009 | Garden
Lawn mower
i dont understand the pulling the button - do you mean push the primer button - if you mean primer button it sounds like the high speed jet in the carb is dirty and needs service- you can attempt to start and once engine fires have someone continually push primer to keep running it ma clear the blockage - did You check the fuel tank for any water ?
Oct 19, 2008 | Mtd 22" Yard Machine Push Mower
Garden Logo
63 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
