Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Washing machine will not drain
WASHING MACHINE WILL FILL BUT WILL NOT DRAIN. MY COMBO STACKABLE WHIRLPOLL LTE623DQ3
  • Anonymous Mar 15, 2014
    washer does not drain
  • 478 Answers
You'll need to pull off the pump.You can tilt the machine to gain acess to the pump,a screwdiver can be used to pry the clips off that hold the pump to the motor. you can leave the hoses connected, but try to turn the inner reciever of the pump to see if it is stuck .
Posted on Mar 13, 2009
What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
Dec 23, 2014 | Kenmore 3.4 cu. ft. Capacity Compact...
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
LgWM2277HB washer will not drain and makes high freq whistle when trying
Open the access door door on the front lower left of the machine and clear the drain filter.
Nov 17, 2012 | LG WM2277HBW XL Front Load Stackable...
Stackable washer won't drain water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag LSE7806A Top Load Stacked...
My GE space saver stackable washing machine will
Im haveing the same exact problem on the same exact machine... I have taken all the pannels off, and drained the water. I was wondering if there may be a way that the pump lost it's prime and needs to be re-primed? (wishfull thinking on my part.) There was no indication that the pump burnt out, it just stopped working instantly with no symptoms. The other functions seem to work, it will agitate the laundry, and then will just stop when it comes to the pump cycle. Any help is appreciated. Thank You.
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
The water in my stackable washer and dryer wont drain
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
May 19, 2010 | Maytag LSE7806A Top Load Stacked...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire Stackable Front Loader Washer
Jane, check to make sure that the drain hose has a air gap in the drain. Sometimes you will get a siphoning effect if you don't have the gap or it is pushed down to far in the drain. If this is not your problem, it's probably a timer issue...Catriver..post back
Oct 04, 2006 | Frigidaire GLGH1642DS Front Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal De
