Question about Pioneer PD-R555RW CD Recorder
I can not get my CD recorder to record
When I press record on my pioneer CD recorder, it comes up on the display "pro-disc". The red record light will not come on, and I can not get it record, just play CD's. It does recognize that the blank CD is blank, and will display "new disc" then when I press record, it just displays "pro-disc". Does anyone know how to correct this?
  • Anonymous Dec 30, 2007
    Dug out an old TDK  CD-R XG disc and the red (record) light came on and off we went, transferred vinyl John Cale 'Honi soit' to CD.
    Ta.
  • Anonymous Mar 28, 2014
    it plays cds ok, but will not record onto blank discs
  • 56 Answers
You should use consumer cd's that are rather expensive. You probably tried to record a recordable cd-rom (a cheap computer disc). It's not possible to burn a pro-disc (computer disc) by using your Pioneer, and that's why you got that message on the screen. Refer to the user manual of your cd recorder and learn what sort of blank cd you should use.
Posted on Aug 07, 2007
SOURCE:
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
This is nearly always due to cable problems. I think the cheaper optical cables can get 'kinked' quite easily, which would stop the signal coming through properly. So, first check your settings to make sure the correct cable type has been selected. If that's OK, try replacing the cable with a good quality one.
Jan 02, 2014 | Pioneer Computers & Internet
Hi - I have been recording some of my vinyl albums onto CD's for several months now. All of a sudden, when I went to use the turntable yesterday, I can't get the Record light to light. What am I...
If the red indicator on the record button does not light, reload a record-able dics, wait a few seconds until "NO TOC" and "CR-R" (or "CD-RW") indicators light on the display, and press the record button again. BE sure your using the CD -R or -RW disc and make sure to use a disc bearing the "Digital Audio" mark on it.
Richard Roth
The FixYa Team
Aug 09, 2011 | Teac GF350 Turntable
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Do I just push finalize to finish the burning of the cd?
after you've finished recording press 'finalize' the recorder will then get ready for finalizing and then a countdown time will appear in the display eg '1:20' once this appears press 'play' and the recorder will start to finalize and the digits will count down to zero, once this has finished, your disc is finalized.
Feb 01, 2010 | Pioneer PD-R555RW CD Recorder
My problem is when i record it show pro dish
Do you mean "pro disc?". Home CD Recorders are limited to recording on CD-Audio or CD-Music blank media. CD-R's are considered 'pro'. Get the right media.
Jan 04, 2010 | Pioneer PD-R609 CD Recorder
I want to use the optical input s a dac without going through the recorder
Put in a blank or unfinalized disc, press Record until Record Manual shows. This is similar to an old-school cassette deck being in Pause/Record mode. That should do it. The input signal will be present on the audio outputs (both digital and analog).
The manual isn't specific about how long you can remain in Record Manual mode without starting to record on the CD. My Pioneer has a Monitor function so I don't need to place a blank disc for this.
Jan 03, 2010 | Philips CDR870 CD Recorder
Perfect in recording CD's recording of CDRW's (TDK CDRW AUDIO nor MAXELL CDRW XL II music) not possible. how to fix?
If the CD recorder records data discs, and is not a CDRW recorder it will not record on them, also there would be no reason to record a audio CD if the unit records data discs
Dec 11, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
Hi can i record on my pioneer pdr 609 cd without using the remote control,as ive purchased a unit with out one and cant get it to record, thanks
Hi John
You should be able to record without the remote control; make sure you have a blank disc in place, then press the 'RECORD' button on the front; it should go into recording standby mode. When you want to start recording, press the button below the REC BALANCE buttons (the play/pause button, marked with a triangle and a II symbol) and this should get you going.
Try it and get back to me if not.
Hope it works!
Kev
Jul 25, 2009 | Pioneer PD-R609 CD Recorder
Can't get it to record
I experienced this problem a long time ago, i believe that it was because i tried to use a normal data cd-rw but the unit only reads audio discs. It has to be a cd-rw for audio only (will say cd-rw audio on the disc, whereas if it is a data disc it will simply say cd-rw.) Hope this helps..
Mar 13, 2009 | Pioneer PD-R509 CD Recorder
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
Feb 23, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
Pioneer PD-R555RW CD Recorder Logo
441 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
