Question about Dryers
I just replaced part number 61927
I just replaced a heating element for a speed queen by raytheon m/n:aem 497l2 and am looking for a wire diagram of that part to verify that i placed the wires in the same spot because i am still not getting any heat. also is there some other reason that it wouldnt be heating?
  • 63 Answers
On most dryers ive worked on, follow wire from element, right before that is a senser..prob bad...PS also two wires to element..does not matter which is which
Posted on Mar 13, 2009
I DONT HAVE A GAS DRYER AND I JUST BOUGHT A HEATER ELEMENT JUST DON'T KNOW WHERE TO PUT IT ON MY SPEED QUEEN DRYER
If does vary by model of SpeedQueen dryer,but typically the heat element fit in the bottom or the rear plate the supports the drum..reply with model number and i will tell you where yours goes.
GENE
Sep 04, 2011 | Speed Queen AES68AWF Gas Dryers
Ignighter workis and burner has flame but will not keep burnner lit. speed queen dryer. made by RAYTHEON
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Aug 06, 2011 | Dryers
My speed queen aem497w is 15 years old and quit drying recently, no heat ,drum spins as usual, vent is clear , what gives ? Dave from Canal Winchester,Ohio
Hi - I am not too familiar with Speed Queens, I work a lot on Maytags, however the principals are the same.
So here goes - there is most like to be an open circuit due to the following , bad/burnt wire or terminal somewhere close to the heat elements, open circuit on the two thermostats & the over-temp fixed close to the elements, the outside chance of the thermal fuse blown.
One would noramally gain access thru the front (Best) and often from the back, sorry I cannot guide you on this as stated earlier.
Jun 17, 2011 | Speed Queen Dryers
I have a speed queen electric dryer model number aem45300. problem the dryer runs but does not heat. We cleaned out all the area that contained lint. Is there a reset button for the heating element in...
There is no reset button, check yoru breaker, by turning FULLY OFF (somewhat forcefully off) then back on and test again.
All thermal limiters will auto reset when cooled...
Mar 04, 2011 | Speed Queen AES17AWF Electric Dryer
Need older Raytheon v720/ v820 sounder transducer pinout
Did you find it? i´m triying to get a wiring pinout diagram for a V8010 transducer. Thanks, regards from Spain
Apr 21, 2009 | Televison & Video
How do I open the Speed Queen top loadto replace the pump?
there should be two screws at the bottom of the front panel if I remember correctly. then the top of the fron panel just unclips
Mar 26, 2009 | Washing Machines
Dyrer won't heat...
I can not find a diagram using your model number.
However, most Speed Quenn dryers have 2 screws on the bottom right and left sides of the front panel.
Unplug the dryer.
Remove the 2 screws.
Lift the panel forward and disconnect the door switch wires.
Reemove the belt and drum to access the heater circuit.
Jan 20, 2009 | Speed Queen AES28AWF Electric Dryer
Dryers Logo
90 people viewed this question
Top Dryers Experts
