Problems using a USB keyboard with an iMac intel
After installing a USB "Macally" brand keyboard (designed to work with the iMac) and having my iMac "recognize" it, I find that although all the main keboard keys work, none of the NUMBERS on the numerical keypad on the right hand side of the keyboard work. The symbol keys (=. /, *, -, + and ENTER) on the numerical keyboard DO work, but none of the number keys work. I replaced this keyboard with another generic USB full keyboard as well as a stand-alone wireless numerical keypad and had the same results. Neither Macally nor Apple technicitions were able to solve this problem.
My iMac is up-to-date on software upgrades and there are no aftermarket Bluetooth radios attached to my computer.
Good luck!!
  • tedulrich Mar 13, 2009
    I went to the Apple website and looked for keyboard drivers but found none.
    I have actually pressed the "NUM LOCK / CLEAR" key many times to no avail. To prove this, as I stated in my original message, SOME of the keys work on the Numbers Keypad but none of the NUMBER keys.
    Brigadier General:
  • 8,619 Answers
Hi
You can download the driver from this link.
Macally Keyboard Driver
If you are unable to solve the problem then please revert so that I can provide you further assistance.
Thanks
Rylee
Posted on Mar 13, 2009
  • 10,515 Answers
Pressing the "clear" button, right above the "7" button will switch the mode of the numerical keys from the NUMBER mode and the Curser directional mode (my own termenology lol)Problems using a USB keyboard with an iMac intel - biggrin.gif
Thanks.
  • taran_2005
    taran_2005 Mar 13, 2009
    try , one you have installed the Keyboard Software Update 1.1)
    1. go to your system preferences
    2. select Dashboard & Expose
    3. change the keyboard shortcuts for Expose & Dashboard to - (ie empty)
    4. try your new keys
    5. now you should be able to put back the keys in system preferences (i have mine set to F16, F17 F18 & F19)
    i think the problem is that they had 2 keyboard maps for same acction (one F key & the new key map)
    anyway this worked for me
  • taran_2005
    Are yous till facing an issue?
    If still, we can try some other ways as well.
    hope that your issue would be resolved.
    Thanks.
  • 583 Answers
Oh its just a simple thing .u hve not clicked the numlock key and its activated.click numlock key above the numbers keys to release the lock on all numbersof right number pad
  • 513 Answers
There should be a driver for this keyboard to be recognized by mac, go to macfacture website and look for the mac driver, also if you look for the setting in mac perference for the keyboard , you can change it. try it may be it work.
Best Regards
    1. Disconnect and reconnect your keyboard if it is external. Make sure that the connector is completely inserted into the port. (USB plugs fit into ports one way only, and won't allow you to make a connection if you try to connect them in upside-down.) Test the keyboard again.
    2. Connect your keyboard to a different USB port.
    3. Try a different keyboard on your computer if possible, or your keyboard on a different Mac.
    Try this:
    1. Open Speech preferences in System Preferences. If "Speak selected text when the key is pressed" is enabled, the key combination to speak text cannot be used for other purposes or used to type text--change to a more obscure key combination (try to use more modifier keys such as Shift, Command, Option, and Control). Or, simply disable the "Speak selected text when the key is pressed" option.
    2. Open Universal Access preferences in System Preferences, click the Keyboard tab, and make sure that Slow Keys is turned off. With Slow Keys on, you need to press a key for a longer period of time for it to be recognized.
    3. In Universal Access preferences, click the Mouse tab, and make sure Mouse Keys is turned off. With Mouse Keys enabled, you cannot use the Numeric Keypad to enter numbers--instead the keypad moves the pointer (cursor). (There is an option to enable Mouse Keys with five presses of the Option key; you may want to turn that option off to avoid accidentally enabling it.) If Mouse Keys is enabled and you are using a keyboard with no numeric keypad or Num Lock function, see this article.
    4. If the issue persists, open System Preferences and click International.
    5. Click the Input Menu tab.
    6. Click the Keyboard Viewer "On" checkbox to select it.
    7. From the Input (flag) menu, choose Show Keyboard Viewer.
    8. If the keyboard is connected and detected by Mac OS X, the keys you type will highlight in the Keyboard Viewer window. Try typing to see which keys are not highlighting in Keyboard Viewer.
    9. Open TextEdit (or another text application) and try to type something using the keys that were previously not responding.
  • Try to update your mac firmware, there is update for keypad firmware, go to mac webpage and look for your computer firmware update and i think it should fix the problem.
    Best Regards
Imac bluetooth and usb not working
Simply you can't alone, probably you have problems with your southbridge on motherboard. Usualy this can be solved with rebaling. Is a common problem because - probably - you not clean your mac regulary.
Nov 20, 2013 | Apple 21.5" iMac Desktop
IMac keyboard suddenly isn't working. Mouse works, but I can't enter any typed message.
if it's bluetooth, are the batteries ok and is it showing up in your bluetooth settings? if it's wired, try another usb port
Oct 21, 2011 | Apple iMac G5 Desktop
I have an old blue imac style macally keyboard I just went to use after a long break and I find the keys are all in odd places etc. Has the keyboard forgotten what it is and needsa firmware upgrade or...
go to system preferences>> then click on keyboard>> you can select the language of your keyboard. it may gone to some other keyboard layout that is why you are facing problem.
of if you need to install any firmware. use software update to install update firmware if there are any.
Jun 27, 2011 | Computers & Internet
I HAVE A PROBLEM WITH KEYBOARD OF IMAC 24.How can open this keyboard?
There really are no user-serviceable parts inside an Apple keyboard.
If the keyboard is less than a year old, you can get it replaced for free under AppleCare (unless your problem was self-induced, like spilling a drink into it).
If it is more than a year old, I would recommend finding a replacement keyboard. Keep in mind that a Mac will work with any USB keyboard, and the software will let you remap the position of the command and option buttons to your taste.
Oct 29, 2010 | Apple iMac 24" 306GHz Intel Core 2 Duo...
Just installed my new keyboard to my iMac and the volume buttons do not work. suggestions? it seems most if not all others do work, but i could see this getting pretty annoying my...
Take the keyboard out to your back yard, soak it in gasoline, and light it on fire. That is the only way you will ever be rid of the problems with this keyboard. I'm guessing you haven't even figured out half of the other problems yet. Like the USB ports on the sides of the keyboard being completely worthless. Please burn it and tell everyone you did so no one will but this POS.
Jul 30, 2010 | Macally iceKEY Keyboard
Konica Minolta DiMAGE Scan Dual IV Film Scanner driver in an IMac
DS Dual 4 even works with SnowLeopard on a CoreDuo MBP. But it doesn not support Autofocus when used under USB2. You have to use a USB1.1 Port, if you want to use autofocus function. Every time the software crashes, because you tried e.g. to use autofocus with USB2, you will have to close the application, go to the folder User/Library/Preferences/DS Dual4/... and look whether there is a file name something like "MFSlib...." and pull it to the trash bin. You can start the application again. PS.: Your keyboard USB port is a USB 1.1 port!
Jul 06, 2009 | Konica Minolta Dimage Scan Dual IV Film...
Keyboard and Mouse don't work anymore
Hi, Sorry you are having problems,
Well Marcelo, the first thing to do in a situation like this is to restart your Mac or even better, shut down and restart. So, if you have done this, and still the keyboard and mouse don't respond, and, as you have mentioned, you have tried the other USB ports on the back of the Mac, it sounds like somehow, unexpectedly, your iMac motherboard got a shock of some kind and it killed the USB controller....
Last thing to try is to unplug the iMac completely of everything and let it sit for 10 minutes and then plug just the keyboard and mouse back in and try to see if that does the trick..
Otherwise, Apple will cover this if it is still under warranty.
Good Luck.
Jan 12, 2009 | Apple iMac 24" Desktop
Install macally icekey keyboard to windows?
It is only for Mac, there are drivers available from the site, all OS and OSX.
Driver - Macally Peripherals
www.macally.com/driver
Keyboard & Mouse · Bluetooth & Wireless · Webcam · Hub & Adapters ... usb. IceCam. IceCam Driver for OS X 10.4 to 10.5 ( updated on 2/16/2008); IceCam ... ICEKey installer for PowerPC and Intel-based Mac OS 10.4 to 10.6(32-bit system only) ... USB 3.0 to Gigabit Ethernet driver for Windows XP/Vista/7/8 (9/10/2013).
Amazon.com: Customer Reviews: Macally USB Slim Keyboard - ICEKEY
https://www.amazon.com/Macally-USB-Slim-Keyboard-ICEKEY/.../B00006HYP6 ... and review ratings for Macally USB Slim Keyboard - ICEKEY at Amazon.com. ... F9 for me shows application windows, F10 isolates the window and F11 ... Macally USB Slim Keyboard ICEKEY Google Search
Mar 13, 2017 | Macally iceKEY Keyboard
Keyboard and mouse work only intermittently
yeah.. maybe you have a defective keyboard.. better look at your warranty now..
Sep 30, 2006 | Macally IKEY Keyboard
Computers & Internet Logo
121 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
