Question about Xerox WorkCentre 7132 Multifunction Color Copier RECONDITIONED
Error code 124 315
Printer will not work displays error 124-315
Canon MX922 printer displaying code C000
Try switching printer off then unplugging the power for 15 or so minutes. If that doesn't work and same error pops up when you turn printer back on, contact Canon.
good luck
Feb 28, 2015 | Canon PIXMA MX922 Wireless InkJet MFC /...
Printer error. Turn off the printer, and then
So, if you followed the procedure you describe the printer should be working again. Or is it?
Nov 02, 2013 | Canon LASER SHOT LBP-2900 Printer
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
My printer canon 4412 not work the display showing on main switch e202-0002
hi my printer canon mf 4412 printer is not working it is showing error batten red light showing , display is not showing pls solve problem pls it is urgent
Apr 05, 2011 | Office Equipment & Supplies
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
Feb 15, 2010 | IBM Infoprint 1352 Laser Printer
Printer kodak 5300 says error code 6203
printer needs to be replaced
call kodak at 18004216699
Feb 08, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Will not print
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 27, 2009 | HP C6280 All-in-One Printer
Error code on 5300 printer
unplug the power chord at the back of the printer
wait for 5-10 sec.
replug power chord
turn on the printer
Jun 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Getting started
not sure, but try to turn printer on and off, remove and replace printehead, to see if this will work,
Mar 30, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Xerox WorkCentre 7132 Multifunction Color Copier RECONDITIONED Logo
62 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
Outback Jack
Outback Jack
Steven's...
Steven's...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
