Question about Home
WANT TO CHANGE FROM 110V TO 220 WOULD LIKE TO FIND WIRING DIAGRAM IF THERE IS ONE AVALABLE FOR ASW12F1FDA00
    Sergeant:
    Champion:
  • 234 Answers
It's a lot of changes to convert the voltage.You know you got to buy new heating elements.contacter.Theonly going to save very little power bill.
Posted on Mar 13, 2009
CAN I WIRE THIS PUMP TO RUN OFF 110 OR DOES IT ONLY USE 220
There should be a wiring diagram on the side of the motor. It will show wiring for 220V,or 110V, or both.
Jun 22, 2015 | Pool & Spa
How to wire it from 110v to 220v...
Most pumps have the eiting diagam on the outer motor housing. What brand is the pump? Some motors have a jumper that is moved over to 220v or 110v post and the red/black(220) or white/black(110) stay on the regular screw terminals. Ground stays on the same terminal usually a green screw
Jul 21, 2013 | Utilitech 1-HP Lawn Pump UTP10P1
Hayward wiring diagram
yes see side of motor for high voltage wiring
Apr 23, 2013 | Hayward 1hp Power Flo Matrix Above Ground...
Convert 110volts angle grinder to 220 volts
change armature stator 220 volt
Jun 30, 2012 | Saws
I have a 110v power input Paradigm PDR10 and would like to convert it to 220/240. I'm sure it's a case of change the series connection to parallel on the transfomrer but I'm not sure the exact functions...
I have the same problem. An external transformer would step down the voltage, but it wouldn't help with the frequency, which would still be 50Hz. Paradigm says there's a risk of burnout if an unmodified PDR-10 is run at 50Hz rather than 60Hz
Oct 16, 2010 | Paradigm PDR 10 Speaker
Wirng connecions for 110v pentair pool motor???
There shopuld be a diagram on the nameplate of the motor, or on the cover for the wiring compartment, or there is some stamped indication at the wiring lugs that tell you where to put your feed and what position the internal wires are to be in or the jumper .. for 110 volts or 220 volts.
May 29, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Dec 03, 2009 | Craftsman Saws
Ghart106 asked:
There is a wire diagram on the inside or outside of the motor housing. There is a simple wiring switch that you can do to change the motor from 110 to 220 or vice-versa. Everything you need to know is on the motor.
www.cpo2go.com
Sep 06, 2009 | Pentair 1.0 Hp Whisperflo Pump
Need to change wiring from 220V to 110V
Black or red is hot; green is ground; white is your neutral. The black should be for 120 and the red for 220.
Jun 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Home Logo
56 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
