Question about Garden
Do not have any power on the left side of the coil
When using spark plug tester, there is no fire on the left cylinder coil on a Briggs&Stratton 21 HP, OHV, twin cylinder engine. The model is 407777 and type is 0124E1. What could the problem be?
  • 13 Answers
Check that the air gap between the ignition armature not getting spark and the flywheel are between .008 and .012. Also note that the engine must be producing, by Briggs standards, 350 rpm to produce spark. It's rare for an ignition armature (coil) to go out, but it does happen. If a new plug on that side and correct air gap don't solve the issue, hit me back up on it.
Posted on Mar 13, 2009
13.5 HP Briggs & Stratton engine will not start
Check for spark from the coil if you have a spark tester use it if not remove plug and leave it attached to the coil wire turn engine over if you do not have spark either the ground wire is not releasing or coil is bad
Nov 09, 2013 | Mtd Garden
I have a 20 hp briggs and stratton that wont get any fire
Check the diodes in the wires to the coils. Trace the wires from the coils, and they should join together into a single wire. In the junction of the wires, there is diodes. There is a possibility the diodes burnt out which will not allow power to the coils. My experience was when one burnt out and only one cylinder would run. I replaced the wiring and both cylinders worked fine.
Jan 30, 2013 | Briggs & Stratton Briggs Stratton Intek V...
One cylinder not firing
First take the plug wire off the plug to the one not firing..start and then using a pair of pliers hold the plug wire away fro the plug insert a rubber handled screw driver in the plug wire and make screw driver contact with the plug end..there should be spark if the coil is good..if not that coil must be replaced...good luck
May 09, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Shuts off and runs weak when hot
My name is Dane and I'll try to help you with your problem. It sounds as though you have a weak coil to me. Sometimes a coil will either completely stop producing spark or will get weak after it gets hot from a running motor. You can buy a coil tester from any automotive supply. just take the spark plug wire off of your plug and attach the tester between them. Crank the motor and see if the tester lights brightly. Be careful, the engine can still start with this installed. If the light is weak, replace the coil. I hope this helps. Thanks! Dane
Nov 30, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
20 hp intec runs wide open
24 hp briggs. replaced cam, exhaust lobe was unhardened. now it doesnt fire on that cylinder. plug is wet. spark tester shows spark,please help.
Mar 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Shuts off after running a while
Given the fact that you offer absolutely NO information about what "IT" is, I am going to guess at a solution for you.
I am assuming that you have a one cylinder Briggs and Stratton engine mounted in a riding lawn mower that sounds like you are dealing with a defective ignition armature, commonly know as the coil.
You can verify this by obtaining an in-line spark tester, the kind with a neon bulb that will show a visible spark while the engine is running,
Insert your tester in the spark plug wire and connect it to the spark plug, start the engine and run it until it "shuts off". Immediately try to restart it while watching the spark tester for a visible sign of spark. If you see no light flash or a very weak looking light in the tester, replace the ignition armature/coil.
Oct 29, 2009 | Briggs & Stratton Garden
Briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Oct 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Not firing
After you check the key and key way,Check the coil wire to see if it has any breaks in it,If no breaks are present,Replace the coil.
Jun 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Have a problem with a BS600-W-1 generator
With your model number I could see if it has a low oil safety switch I have seen them go bad (check your oil level )
With all wires un plugged from the coil you should have spark
if not coil is bad .
Use another spark plug to test for spark, ground the side of the plug by holding it against some-ting metal on the engine , spark
plug wire hooked to the plug. leave a spark plug in the cylinder
head so gas wont fly out and hit the test spark plug catching fire (seen it done).
Good luck
Feb 02, 2009 | Briggs & Stratton 11HP 6200W Es Generator
Garden Logo
258 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
