Question about HP Pavilion dv6000z Notebook
Dark unreadable screen
I have an hp pavilion running windows xp- the screen is dark and unreadable. How do I fix this?
  • HP Master
  • 32,281 Answers
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 13, 2009
I HAVE AN HP PAVILION DV1000 WHEN I TURN ON THE COMPUTER IT GOES TO ?WINDOWS START SCREEN WERE IT ASKS YOU HOW DO YOU WANT TO START WINDOWS? THEN IT IMMEDIATLY SHUTS ITSELF OFF?
May be some applications are causing the root cause of an issue. To fixed this problem start the computer in safe mode. For the instruction open this link.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/boot_failsafe.mspx?mfr=true
And then type msconfig in Run box. Goto start up and disable unwanted program and restart your computer. Then check your issue has been fixed or not.
Sep 04, 2011 | HP Pavilion dv1000 Notebook
I have a HP PAvilion dv5-1125nr and I recently encountered a problem where on startup it shows a white screen. I tried looking at it from all angles to see if there was a faint image but there was nothing....
no photos of white screen presented or posted.
is it white in a dark room???????????
DV5-1125nr (9 years old (first made date) RTC COIN cell time? sure. page 59 tells you how.
http://h10032.www1.hp.com/ctg/Manual/c01550108
lacking any photos , it be impossible to fix this talking in text box.
no?
as they say ,seeing is believing, what you call white I call black.
white on sunny beach, or black in dark room, can be the same.
PAvilion dv5-1125nr
always post what a pC does in the dark, its best.
all text seen , all logos seen (hp or compaq)
any boot screens, any log in screens.
and if the "hit F10 key to enter HP setup" is missing on said screen as seen now for 9 years running.
if that text is missing,
remove the big battery in rear of LP,they short, so get it out now
and first., do that first. always,,,
then run on AC power,
do the HP long reset? (battery out, ac pack pulled
push power button 10 to 30second, not use the ac pack only
it can run on AC forever, end ever , no problems.
do so now.
got that that 9 year old text now? in the dark, ok?
The F10 is BIOS hot key, power on and quickly hammer F10
bingo for BIOS. see that? see those screens, those are first.
if BIOS is dead, it can not boot any OS made.
BIOS does the booting job, see?
here is your support page. at HP, Fixya is NOT HP. so....
https://support.hp.com/us-en/product/hp-pavilion-dv5-1100-entertainment-notebook-pc-series/3744201/model/3795325/manuals?jumpid=reg_r1002_usen_s-001_title_r0001
this OLD PC, is CCFL back lighted, all are.
2010 year is the magic hear we went to LED backlamps.
but your PC is 2008, see?
CCFL do these things
dim, go yellow, do dead, go intermittent and blink(strobes)
if dim, AS I SUSPECT , then its that. (brightness set to max)
CCFL tubes are 99% caused
the HV inverter is 1%
here is the tube sets.
https://www.ebay.com/itm/CCFL-Backlight-for-15-4-LCD-HP-Pavilion-dv4400-dv5000-dv5100-dv5-1000-1100-1200/401259562873?hash=item5d6cef0779:m:mcD2SCb17BxyIvQPKdpd78A
here is the inverter (high voltage inverter for HV CCFL tubes)
https://www.ebay.com/itm/HP-Pavilion-dv5-1125em-dv5-1125eo-dv5-1125es-dv5-1125nr-laptop-LCD-inverter/121175375836?epid=1758409030&hash=item1c369d7fdc:g:CXEAAOSwRbtaAU5l
if you tell what it does in the dark , all things
good or bad,.
answer get 10x smaller, or in fact , dead accurate.
why not just get it fixed by a tech.
all old laptops do this, EVERY SINGLE ONE.
Dec 14, 2017 | HP Pavilion dv5-1125nr Notebook
My hp pavilion a1110n is frozen on the blue screen and it won't reboot. I've tried to use the command keys but it does not respond.
To solve a frozen screen error, please run a bootable windows XP and repair "c/windows" on the hard drive. Follow the instructions carefully and let the system restart and proceed. Use the key written on the XP CD. After repairing, please an Anti virus (Kaspersky 7 or 2010).
Good Luck!
Jun 17, 2010 | HP Pavilion a1110n (PX743AA) PC Desktop
"Input Not Supported" after adjusting screen resolution
What resolution are you trying to run? The native resolution for your monitor is 1440 x 900, setting to that should fix your issue
Jul 13, 2009 | Acer AL1916W 19" LCD Monitor
How can I install Winxp on HP pavilion DV5 laptop ?
You're Hard Drive may be dead. If XP is starting to install and then it goes to the Blue Screen of Death, that's most likely your problem. There's a slight chance that you're power inverter has a fluctuating power level that is causing a disruption, but that's very unlikely. Have you done any tests with any boot CD's to check the hard drive's function?
Jun 09, 2009 | HP Pavilion dv5110us Notebook
My emachine M2352 tries to load windows xp but can't do it.
If you press F8 button before XP boot screen then there you can choose safe mode. Can you run XP on safe mode?
Dec 09, 2008 | HP Pavilion zd8000 Notebook
Hp pavilion dv4000 screen is dark and unreadable
hi this is a website where you can dawnload service repair manual
http://www.laptop-repair.info/hp_laptop_repair_manual.html
check with it
regards
Sep 18, 2008 | HP Pavilion dv4000 Notebook
When starting my DV4000 - the screen is dark other than a cursor in the left corner.
That error indicates a hard drive problem. You probably have to replace the hard drive.
Nov 23, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv6000z Notebook Logo
216 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
