Question about Disney DTD1363-CAR 13" TV/DVD
Remove back of TV
I need to remove the back of the tv to remove crayon that my son pushed in through the holes.
You have to take off the tires to get to the screws the lugnuts r on by clips then you can get the back off
Posted on Apr 09, 2009
    New Friend:
I've taken one screw out of each tire, but cannot get to the other two, because the case is in the way. ?!?
Any ideas?
Darren
Posted on Oct 16, 2013
I have an Hitachi P42H401 72" my son was playing a game on his Xbox360 the othe day the TV was fine and has been in the middle of his game the TV screen went to no signal and the TV shut off and has been...
I did some research for you. This is a known problem with this TV. Remove the back cover, blow out all dust, then disconnect and reconnect all cables leading to and from the power supply. (Do one cable at a time). One of them is not making proper contact. // Your son playing a game is an interesting coincidence. The guy who figured out this ''fix'' had the same exact thing happen. Only in his case it was his niece who played the video game. // Best of luck to you...
Jan 01, 2015 | Televison & Video
Tip
Quick Fix for Ugly Nail Holes
Start by using the blunt end of a pen, or anything similar, and tuck any ragged edges into the hole so that the wall suface is flush and smooth again.
Now sneak into the kids' room and steal their crayons! No matter what color your walls are, you should be able to find a combination that will match the wall great.
Scribbling the crayon back and forth in every direction will fill the hole with crayon wax. Smooth it out between layers with your finger tip.
Start with a light color and darken to match. Baby blue with only a dark blue crayon? Fill the hole w/ white then lightly blend the dark blue in a little at a time. Maroon wall? Red then add brown. You get the idea.
When you're happy with the color just blend the excess away and your nail hole will be practically invisible.
on Dec 01, 2009 | Hand Tools
How to remove two discs from supersonic tv drive
just turn off the power and open the back up and you should be able to get them, PLEASE TURN ALL POWER OFF BEFORE HAND - AND DISCHARGE THE TUBE BY LEAVING THE PLUG OUT AND PUSH THE POWER ON BUTTON ON - DO AT YOU OWN RISK
Jul 21, 2014 | Supersonic FC-2245 13" TV/DVD
Changing the LCD lamps
You may follow the below mentioned steps to replace the lamps :
1. Power off the LCD TV. Unplug the AC power cord from the television and the electrical socket or power strip.
2. Locate the plastic or rubber grommets or screw hole covers on the rear edges of the LCD TV. Use an awl or small flat head screwdriver remove the rubber pieces from the screw holes by gently inserting the tool into the hole and prying out the cap. Note that on a few LCD TVs, the grommets or screw hole covers may be on the front face of the unit.
3. Loosen and remove the screws in the holes from which you removed the plastic or rubber grommets. Set the screws aside and keep them together.
4. Remove the plastic shield that protects the input ports on the rear of the TV if the unit has one. To remove the shield, use the awl to pry the plastic tabs loose or remove the retaining screws with the screwdriver.
5.Use the flat head screwdriver or awl to separate the front and rear pieces of the monitor casing. Start on the lower edge of the casing and gently pry the two pieces apart. Work your way around the outer edge of the television and separate the tabs until you can pull the front face off the casing. Remove the front bezel piece from the television.
6. Locate the inverter board below the LCD screen on the TV. The inverter board is small circuit board with wire connector plugs on either side. Disconnect the plug on the right side of the inverter board that leads to the backlight lamp bulb.
7. Use the Phillips screwdriver to remove the screws on the edges of the LCD screen that attach it to the rear part of the TV casing. After you remove all of the screws that secure the LCD screen, place the screen face down on a soft towel.
8. Remove the screws that secure the back light lamp in its track. If the wire leading from the back light lamp to the inverter board uses clamps or ties to secure the cable, disconnect or remove them. Remove the backlight lamp from the TV casing.
9. Insert the new backlight lamp into the track and secure with the retaining screws you removed from the old bulb assembly. Run the wire through the clamps or ties as needed to position the wire plug next to the inverter board.
10. Realign the LCD screen with the screw holes in the rear part of the TV casing. Insert the retaining screws and tighten them. Connect the wire plug from the back light lamp to the inverter board.
11. Replace the front part of the TV casing and snap into place. Reinsert the retaining screws in the holes on the rear of the TV and tighten with the Phillips screwdriver. Replace the plastic or rubber grommets and push them into place securely.
12. Reconnect the AC power cord and plug it into the wall socket. Power on the TV and use normally.
Feb 06, 2012 | Televison & Video
I want to mount my tv on the wall and i do not which screw do i have to remove from its back
No you dont need to remove the back it actually has holes for the mount already just buy an universal mount that fits your TV and use the screws that comes with it.
Dec 24, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
The screen faded to black. Followed by a humming noise, and a burning smell. Now the T.V. won't turn back on and the DVD is stuck inside.
Probably something shorted out in the power supply. Sadly these days small TVs are cheaper to replace than to repair. To remove the DVD look for a small hole on the DVD tray door. Straighten a medium sixed paper clip and push into the hole and the DVD tray should release and open. Remove the DVD and toss the TV.
Sep 23, 2009 | Coby TV-DVD1350 13" TV
Hi,my dvd lead pin heads are stuck in the holes in the back of the tv - any way to remove them safely?
they can be pulled out with tweezers or fine pliers.there is no risk of a shock since this is a signal circuit.
if you can not get them out from the back,you will have to remove the back of the tv and push the pins out from the inside.
as long as you stay away from the high voltage section and just deal with the panel that houses those jacks,you will be ok.
Sep 09, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I need to remove tv stand from my Soyo DYLT032D to mount on wall, Also what screws do you remove in back of TV? Thanks...
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
May 09, 2009 | Soyo DYLT032D 32 in. LCD Television
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Grandchild scratched large tv screen with sereated knife
It is not repairable..A new tv will have to be bought.
Nov 09, 2008 | Sony Televison & Video
Disney DTD1363-CAR 13" TV/DVD Logo
277 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
