Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Pictures missing camara sat on top the microwave and now some pictures are missing people told me its do to the microwave
  • 8 Answers
Could be true... microwave uses a small magnatron, it not important what it does, whats important is that a magnatron creates a strong magnetic field. this is something that the memory card in your camera would be susceptible to. since the memory card uses tiny magnetic pulses to read and write data.
Posted on Mar 13, 2009
I have a brand new camara with about 300 photos I am trying to download pics to computer and the camara will not read the card - i have turned on & off removed card and re-insurted and made sure...
The Canon EOS Rebel G is an all-plastic 35mm SLR film camera there is no way this camera model can download pictures to a computer, it's a film camera. If you have miss printed the model correct the error and resubmit the question.
Nov 27, 2010 | Canon EOS Rebel G 35mm SLR Camera
Can I download pictures from my digital camera onto my Dell Latitude d410? If so, how?
You can download from any digital camara.Load the CD that came with the camara or obtain one if you can. You need the interface cable that is purchased seperately. You do not specify the camara spec so you will need to Google the" model and pc interface cable". If you have the cable then the next step is the camara driver which should be on your cd that came with the camara. Plug in the cable to the camara and to the USB port on the PC (make certain the camara is set to the Play position or PC). Windows will ask for the driver location. Insert the cd and continue. If windows does not see the driver you will need to locate it manualy from the cd or on line and download it to your desktop from the manufacturers web site. All camara companies have a support website for the drivers. Once the drivers are loaded then you need to switch the camara to the Play position so it can be seen by the computer. Go to the control panel in windows and select system then hardware then devices. If all went well you should see the camara listed as a device. Now you need the camara software or a picture viewer from the web. Here is the web kocation http://en.kioskea.net/telecharger/telecharger-653-picture-viewer
If all went properly 1. driver 2. picture software then you should be all set to handle your pictures. Good Luck Phil pmgibs1@verizon.net
Feb 20, 2010 | Dell Latitude D410 Notebook
A 730 digital camera pink GE
It sounds like you've had an incredible run of coincidental luck. Although this problem does happen, it doesn't happen that often. Could it be that it has gotten sat on, even while in a camera case? (I'm stating the obvious) They cannot be flexed too much. The lcd panel on the back is quite hardy, but the connection is a little more sensitive. Sorry I didn't have a definitive answer for you.
Jan 06, 2010 | Cameras
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
Cold air inside microwave
You are probably missing the outside steel damper,you might have it laying on top of unit.or if you had it service by the same guy that did mine .He was going to leave it of,he told me there was no need for it.Well i do H.V.A.C.and when ever you are piping to the outside you need a damper,not just the one on your siding,but one further in.
Dec 31, 2008 | Microwave Ovens
Quickcam camera icon is missing?
Do you mean the desktop icon itself, or the taskbar icon?
If you just want the desktop icon back, navigate to "program files / logitech/ quickam" folder. Right click on the "quickcam" (it will have a pic of the eyeball camera). Click "create shortcut". Drag that shortcut icon to the desktop.
To make the the taskbar icon, make another shorcut, and drag it to the taskbar.
Oct 06, 2007 | Logitech QuickCam Pro 4000 Webcam
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
