Question about Home Security
Overhead door opener model 1026 garage door opener
How do I remove the chain to replace the carrier
  • 6 Answers
SOURCE: Craftsman Garage Door Opener Won't Open
When mine did this, it was because the nylon gears that drive the chain had stripped. My wife had to live without the opener for a week or more, but I was able to find a new gear kit online and replace the damaged gears. It wasn't difficult.
The other option is to buy a new opener.
Posted on Dec 07, 2008
  • 118 Answers
SOURCE: Garage door opener motor doesn't work.
2 flashes is a safety eye issue, but you problen is most likely that the chain is not sync with the limit setting. Take the bottom off the gear and sprocket assemble and rotate center limit srew until it is in the same position as the trolley.
Posted on Jan 30, 2009
  • 3197 Answers
SOURCE: need a manual for sears model 139.18856, 1/2
According to Sears your model number is bad. Double check the number and they will have the owners manual with complete installation instructions.
Posted on Sep 25, 2009
SOURCE: how do you program an Overhead Door garage door
Click the button on the overhead unit . it's square it will light up. Click your remote ,it will flash and then it's done
Posted on Dec 30, 2009
  • 10865 Answers
SOURCE: overhead light stays on all the time on craftsman
Hello. If the light stays on all the time check these:
A. The light time delay on the opener will keep the light on for approximately 4-1/2 minutes after the system has be activated, then will turn the light off automatically.
B. If the opener has a worklight switch (which is supplied only with a four-function wall console), slide the switch to "OFF" position.
C. If the opener has a pedestrian switch (which is supplied only with a four-function wall console), the light will stay on for 4-1/2 minutes after the pedestrian door has been opened.
Posted on Mar 31, 2010
I have an overhead garage door Legacy 496cb/d that stopped 3/4 of the way in the down motion. It now will not open or close and only clicks. The lights work and power is on.
If this picture at the link shown looks like yours, the red and white cord with the red plastic piece needs to be pulled to disconnect the automatic door opening chain.
http://www.aypapaquerico.info/overhead-door-legacy/overhead-door-legacy-large-size-of-garage-and-modern-overhead-garage-replacement-with-legacy-opener-overhead-door-legacy-496cd-b-manual/
Then, pushing the garage door fully open should move the mechanism back to connect in the ceiling. Then the remote control may work. If not, seek a repair service.
Mar 18, 2018 | Building Materials
Why does the overhead light on my garage door opener go off & on without any reason, day or night, even when door is not in use?
There's a gremlin living in your overhead light.....lol. The circuit board in the opener has the timer for the light. There's a component that's beginning to fail on it. Replace the circuit board.
Jun 29, 2015 | Craftsman Garage Door Opener 1/2 HP Chain...
The drive chain of my lift master doe not turn when I try opening my garage door even the garage door is disconnected
Sounds like the gear inside the garage door opener needs to be replaced.
If you take the cover off you should see a lot of white powder inside the bottom of the garage door opener case.
You will also see a large plastic white gear that it shredded.
Feb 15, 2015 | Building Materials
Genie 1024 remote programming
On model 1024 genie garage door the carriage trolley jumping out of the chain what should i do to fix it or replace parts...
Feb 19, 2014 | Genie Company Genie Intellicode GITR-3...
Looking remote chain for Legacy overhead door opener. Model #696CD/B
Legacy openers use the same remotes as Genie Intellicode 390MHZ. Should be able to get one at any lowes or home depot.
Aug 09, 2011 | General Electric GE 13-438 Overhead Garage...
Garage door opener (chain) motor runs in reverse. Trolley slides forward trying to close door, even though it is closed, instead of sliding toward motor to open door. Happened out of the blue - was
Loosen the chain enough that you can remove it from the sprocket. Run the opener until the sprocket turns counterclockwise and stops. With the door in the open position replace the chain. You will probably need to adjust your open and close limits per your owners manual.
May 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor works but does not move chain on half horse sears
Clutch? need more info.. wall mount or overhead? If it's wall mounted it could be the clutch, I don't think overheads have a clutch though. The first thing I'd do is get on a ladder and see if the chain is still attached to the sprocket... good luck
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wayne dalton garage door is humming but wont open
Likely the plastic gears are worn out. Unplug the unit from power source, remove the cover, look at the gears. If worn, it will be obvious from the shavings from the gears. You can buy the gear kit on EBAY for a little as $20 depending on the manufacturer and model. Before removing the chain drive, lock a pair of vice grips on the chain and metal chain rail to keep the chain from turning from its current position. The gears can be replaced without removing the opener. Even if you have to remove the opener, it is a simple task. Most have four bolts that need to be removed and it will be in you hands.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
207 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
