Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
I can't play a DVD recorded on my ZC352MW8.
I just can't read the DVD disc, it will tell me please insert disc.
  • Anonymous Apr 01, 2009
    won't play dvd burned off my computer. says disc does not have play back feature
  • 61 Answers
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD hed cleaning CDs.If still the problem persists, contact near by service center for replacing the faulty Lens.
Posted on Mar 13, 2009
Mini cd wont load in dvd drive
try cleaning the lens with a q-tip and alcohol
Apr 22, 2012 | Toshiba Computers & Internet
Trying to record to disc from VHS After recirding 8 copies, it now reads "Unknown disc, Please check disc" This is a Go-Video VR3845 Unit.
I answered this question previously and the solution remains the same;
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Apr 08, 2011 | GoVideo Go Video VR3840 DVD Recorder/VCR
After copying the dvd video content, and inserting the blank disc, Roxio does not recognize the blank disc and continues to say 'please insert blank disc' I have tried both DVD R and DVD WR. Please help!
If your roxio software does not read or recognize the disc that you are using, you can use other brands of disc to check if the disc that you are using is not compatible with the software.
Cheers . . .
Mar 08, 2011 | Roxio Easy CD & DVD Creator 6...
Last night I installed windows 7. After that my LG DVD writer is not working properly. I can see the DVD RW icon. But when I insert DVD/CD it can't read it and shows the drive is empty. I tried a program...
Hi
You installed windows 7 with the same drive right? After logging in insert the same disc and check whether it is reading or not.If it is not reading check the data cable,(clean and reinsert).
I think the problem is with the drive. When drives gets old it can only read few discs. Writing will fail too. Get a new new drive, nowadays price appr below 1k.( SATA).
Jan 10, 2011 | Computers & Internet
It cannot read the dvd sometimes but it read all cd format
your ODD, Optical Disc Driver, have optic component for read your disc. May be your optic broken. Buy new one. Make sure first, you rent some DVD movies, and play to your ODD. And open some softwares, like a PowerDVD.
Sep 22, 2009 | Dell Studio 15 Laptop
WILL NOT DETECT INSERTED DISCS
Lens dirty, have lens clean with DVD lens cleaner.....
Sep 07, 2009 | Panasonic DMR-E85H DVD Recorder
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
My panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Jun 25, 2009 | Panasonic DMRES15 DVD Recorder
I put a disc (dvd) in and it will start saying it's reading the disc and then will tell me no disc is inserted. CD's play well and so do picture DVD's. But no movies. The movies are brand new and not...
Picture dvds are read with different software than that required to play movies. Make sure that you actually have dvd player software installed on your system, like WindDVD or Power DVD. See this link for a few.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 30, 2009 | Audio Players & Recorders
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
189 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
