Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool ultimate care II super capacity plus ser.# LSQ8243HQO The top half of adjitator is not turning at all. Handiman1125@aol.com
  • Anonymous Mar 28, 2009
    i have replaced the dogs but now the agitator turns in one direction, did i replace it wong?
  • porternd Apr 02, 2009
    whirlpool ultimate care II Super capacity plus 3 speed motor model LSQ9610JT1 series 0701142 type III will not spin and makes a loud noise. Can you help and tell me if it is worth fixing and what it is. Is it the hoses or the motor or the belt?
    Thanks!
  • 188 Answers
If the bottom half of the agitator is turning and the spin cycle works, then the motor coupling is good.
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way). If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
The part number is 80040.
If it there is no agitation or spin, replace the motor coupling.
The part number is 285753A
Posted on Mar 13, 2009
  • 6,784 Answers
This is a severed plastic coupler that the drive shaft uses to engage the agitator. this is connected to the clutch and if its stripped or broken, it will not agitate.
    Genius:
  • 1,066 Answers
You need a new coupler that connects the motor to the transmission...part cost about $20
My whirlpool ultimate Care II Heavy Duty Super Capacity Plus washer Very slightly agitates and don't spin dry
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Mar 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Little AGITATION clothes not getting clean, Spin cycle is fine
Hi Sherrie,
There is a service manual located inside the front left side of the cabinet.I find it easier to turn the washer on it's back and then reach up in the cabinet to get it.Hope this Helps !
Oct 23, 2017 | Whirlpool Washing Machines
Ultimate Care 2 Washer, Bottom half of agitator not turning
The problem is simple and inexpensive to fix. The agitator dogs are worn and need to be replaced. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Read through the instructions and let me know if you have any questions. Use the part number provided for ordering any replacement parts. I hope this helps you.
Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II Super Capacity Plus
BETWEEN THE MOTOR AND TRANSMISSION THERE IS A COUPLING THAT SERVES AS THE BELT PART # 285753A REPLACE THAT WILL SOLVE YOUR PROBLEM
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool gold UIltimate care heavy duty super capacity washer
Well you can check the capacitor with a meter for farads, but it sounds like you have a clutch and/ or gearcase failure causing the motor to overheat. The second thing to do is unplug the washer and check the timer. I would right after the agitation to inspect for heat and burnt connections.
Oct 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
1,485 people viewed this question
Dan Webster
Dan Webster
Sal De
