Question about Refrigerators
Ge model 200d8074p008 My side by side refrigerator is not accepting control panel changes of temperature. The ideal temp is 0 for freezer and 37 for fridge. The actual temp is 29 and 59, is not freezing and neither cooling. I adjust it and it does not save and appears again 29 and 59 temp.
2 Suggested Answers
  • 116 Answers
SOURCE: I have a stainless GE profile PSS26SGPASS side by
HI has the temp held steady at 28? And do you notice if the fan in running in the freezer if you open the door do you hear a fan running, if you do not, then the problem is a bad control board located in the rear of the refigerator behind an small access panel this control board runs about 175-200.00 to buy.
Sean
Posted on Mar 26, 2011
Why is freezer side temperature going from 0 to 7 to 0?
The unit has to cycle or it will freeze up, so to control the temperature this unit must cycle on and off. This is normal for all refrigeration units. If your temps are holding meaning that don't recover then the unit will need some attention. Sounds like your unit based on your information given is working properly. Good Luck
Mar 29, 2016 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Why does the temperature on my ge fridge keep changing to warmer temp?
Make sure the condenser is clean and clear, and all fans are working as they should. Also check the freezer section for signs of ice build up. A good defrost and a cleanup usually does the trick!
If it's in direct sunlight, try to limit the heat with a blind.
Jun 14, 2014 | Maytag MZD2766GES Side by Side...
Fridge freezer temperature like to know what is the best temperature
The freezer temp should be between 0 and 5 degrees and the refrigerator section from 34 - 37 degrees.
Nov 16, 2012 | GE Profile PSW26P Stainless Steel Side by...
What is ideal freezer temp setting ?
dear sir /madam
the ideal freezer temperature is 0 fahrenheit(-18 celsius) for storing food. and - 10 fahrenheit (-23 celsius) is recommend when freezing food.
and generally 3 to 5 celsius (37 to 41 fahrenheit) is ideal for refrigerator
hope answer the question
thank you
please vote!
Aug 17, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Looking for ideal freezer temp
For most freezer sections of a refrigerator, zero degrees F is ideal. -2 to +5 range is acceptable, but the warmer temps will reduce icemaker productivity, while colder temps might make that ice cream as hard as bedrock.
Apr 02, 2010 | GE GSS25SGMBS Side by Side Refrigerator
I have a GSS25WST side by side refrigerator/freezer. I have the freezer temp set to 0 and the refrigerator temp set to 37 but according to the "current temperature" reading on the front panel it says the...
The door light switch controls the evaporator fan which circulates the air through out the unit properly. Replace the bad switch and things should go back to normal. WR23x10161 at about 10.00. Good luck. Rick
Mar 10, 2010 | GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side...
Original motherboard
Hi, When i change motherboard that got fried I change also the Temperture sensor Number: WR55X10087
it is under the cover on the right side
Jan 07, 2010 | GE PTS25LHP Top Freezer Refrigerator
GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
