Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
My two woofers are on the same problem.
Hi! my 15" kiker L7. the rubber cone, come off from the woofer frame. looks like the the glue was't that stong. this happen only on the top side
5 Suggested Answers
  • 173 Answers
SOURCE: solo baric l7 WOOFER... CAN I REPLACE THE VOICE COILS?
polyurathane will fix any speaker trust me my l7 came apart compleetley and i glued it al back with urathane and its bangin hard now and has ben for 6 straite months
Posted on Sep 14, 2008
Shadowmaru
  • 33 Answers
SOURCE: wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Posted on Feb 11, 2009
cobrasdh
  • 39 Answers
SOURCE: my 15
That means you either overpowered the speaker by playing it to loud, You used an amp that was way to powerfull, orif this is a new speaker it may be a manufacturing defect.  Do you have a warrenty?
Posted on Mar 26, 2009
  • 103 Answers
SOURCE: My 12 L7 the rubber
Hi, Jr.
I'm sorry, but glue will not fix this problem. When the rubber or foam edge of a speaker breaks down or deteriorates because of age, it becomes almost like dust, which is why it cracks and then breaks apart and falls away from the speaker. The only way to fix it (besides replacing the speaker) is to replace the edge, or "surround". At this link, http://www.simplyspeakers.com/All-Foam-Kits_c_118-1-3.html, you will find a kit that you can buy to repair your speaker for about $30. The standard 12" repair kit will work if you have an 'angle cone edge attach' type speaker (see the bottom of the page for a picture of what this means). This page, http://www.simplyspeakers.com/speaker-repair-foam-edge-replacement-instructions.html, will show you step by step how to use the kit to repair your speaker.
Good luck, and please remember to rate my help.
Thank you for the opportunity to help you.
Posted on Oct 14, 2010
I have AIWA NSX-RV85. The sub-woofer surround tore leaving just the cone. When I play, The woofer just makes a rattling sound coming out of vibrating cone.Any advise on how to fix my speakers.Thanks
Refit the rubber, you can find itbon eBay, its called reconing actually in this case the cone is the inlybpart wich you dont want to replace... The rattling is beingproducer due to the fact the rubber normally holds the cone ibto positionering over the coils. This rattling is not good can defect your cone. So dont play it roll you got a new rubber fitted!
Nov 08, 2016 | Aiwa Audio Players & Recorders
REPAIR CONE TEAR IN 18"
If the tear is large, or the speaker cone is brittle because of age, you might be best off having the speaker completely reconed. There are companies that offer the service, or you can buy replacement cones and do it yourself.
For small tears (an inch or so long), you can glue a patch in place. I have used a piece of a paper coffee filter as a patch, and plain white Elmer's glue slightly thinned with water. Put the patch over the tear and use a small brush to spread a thin layer of glue over it. Give it a day to thoroughly dry and you should be set.
I have found this repair to be more effective on smaller speakers than on large woofers, though. The woofer cones are more mechanically active. But I patched a couple of 15-inch cones that had been punctured for a friend, and they are still playing after a year. So it can't hurt to try.
Jan 30, 2011 | Audio Players & Recorders
I have a set of cerwin vega AT15's my dog decided to put his paw through the one surround and puntured the paper cone I need total 15" woofer replacements or repair. or I need replacements I can buy and...
Ebay sell Cerwin Vega Surround (rubber bit) replacements. If he has ripped the cone too, appart from replacing his back legs with wheels (joke!), contact Cerwin Vega directly and they will send you out a new "driver". These are easily fitted at home by any one with a screwdriver
Sep 02, 2010 | Audio Players & Recorders
Where can i get a mojo 15 reconed
You'll find out it will cost you way more to rebuild the woofer than to replace it.
Jul 29, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I need the basket gasket for 15'' l7
The only way to get a new one is to contact Kicker directly, and see if they'll sell you one. Otherwise, you'll need to get another woofer. They only sell the replacement parts for the SoloX woofers. Sorry about that.
Apr 28, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Hi there I have a problem with my kickers. Subwoofer l7 15" is blow,I was wondering if there is a repair kit avaible for it or not?
The only Kicker woofer that has a replacement cone/assembly is the SoloX woofers. All of those have what Kicker calls it's SPARE which is a field replacement assembly. They're designed for SPL competitions.
Nov 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Pioneer 4 way ts a6970 what are their wattage
  • 330W MAX.
  • 6" x 9" (16 x 24cm) woofer / 66mm cone midrange / 18mm dome tweeter
  • IMPP composite cone woofer
  • Butyl rubber sound for smoother response
  • Glass-imide voice coil bobbin for higher power handling capabilities
Oct 06, 2009 | Pioneer TS-A6970E Car Speaker
Busted cone (i think)
First try swapping the leads on your source, powering the left speaker with the right channel, and the right speaker with the left, if the problem follows, then the issue is with your source, and not the speaker.
If the cone is torn, then try to patch it, using some basic glue and several layers of tissue paper. White Glue, embed tissue paper in the glue, more glue,embed tissue paper in the glue, do this several times building up several layers. Guessing this is a standard paper cone...
Now if you are still having the issue, could be that the woofer is damaged. Look for a replacement.
john
Aug 19, 2008 | Alesis M1-Active MkII Main / Stereo...
Cerwin vega at60 and dc1515
It is called "dry-rot" and it happens with age to paper cone speakers. I am not aware of any products made to help prevent this problem. But you can always replace the woofers with new one's or find a place that "recones" speakers and that would solve your problem for a long time. If you have rubber surround on the cones, it would take much longer to have any type of dry-rot problems. The "foam" type of surround on the cones is the worst for this problem. Most new woofers have polypropelyne surround of the cones and it would probably outlast you, so replacement with a good quality woofer really is a good option.
Jul 08, 2008 | Cerwin Vega CLSC-15S Subwoofer
Solo baric l7 WOOFER... CAN I REPLACE THE VOICE COILS?
well you can bring it into the place you bought it.. or a place where they sell kicker brand subs.. and ask them for a fix..
they'll either order you another one or.. they'll send it to be fixed.. depends on what it is(note) kicker L7 is made to be taken apart and fixed
Jul 06, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
107 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
