Question about Pool & Spa
Coleman spa horizon 400
FLO light stays on, spa won't work
5 Suggested Answers
  • 8 Answers
SOURCE: Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
Posted on May 09, 2010
adamh294
  • 310 Answers
SOURCE: My Spa needs a new pump. A Max E Pro Pump 2 speed
Yes, and I recommend and install them. Look at the voltage and Amperage information on both as well. It is typical to see 220V @ 12.9 amps. If you find this on both motors, they are the same size anyways.
It would take a while to explain, but motor manufacturers can rate a motor @ 1.5HP or 2HP and it can be the same motor. They use a rating called a "service factor" to screw around with the actual HP of a motor. But even if the 1.5 is a 1.5, it would be sufficient.
Posted on Jan 11, 2011
Testimonial: "This is very helpful but I just was told that because I have an in the ground hot tub the Aquaflo would not work. It needs an outflow? Please comment"
ynogami21
  • 670 Answers
SOURCE: coleman spa horizon 400 flo
please try to double check the water level. Alot of these spas are very sensitive to the water level. One other thing you can check is the terminal board connections. Some times these burn out. Let me know if any of these helps.
Thanks!
Posted on Aug 21, 2011
  • 111 Answers
SOURCE: flo code is on and pump won't start up
Flo = Improper flow or pressure switch malfunction or Flow switch malfunction (system specific).
Before you purchase a new pressure switch:
- Clean or replace your filter cartridge (if its older than 1 yr).
- Check that all slice/gate valves are up/open.
- Check water lines for blockages incl. suction cover & ensure sufficient water level in spa.
Posted on Jan 30, 2012
Hot tub won't heath up cal spa
Could be many things, please explain further.
Apr 11, 2013 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Ned a cap for the filter pump
call thes peope
Aqua-Man Aquatic Service
6890 N. Camino Martin, Suite #110
Tucson, AZ 85741-2273
http://www.aqua-man.com
sales@aqua-man.com
Office: (520) 572-9840
Fax: (520) 572-8479
Toll Free: (866) 400-2782
Jul 24, 2012 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Flo code is on and pump won't start up
Jan 29, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
J-300 won't heat. FLO readout
FLO = It typically for a Flow Switch or pressure switch (heater is deactivated. Pump may also be deactivated).
It is most likely a flow/pressure switch failure.
Before you buy a replacement try running the spa with out the filter cartridge - Checking if dirty cartridge is the issue. Also check that all gate valves are all the way open & locked.
Jan 05, 2012 | Jacuzzi Home
Coleman spa horizon 400 flo is flashing. Just filled spa with water.
Thanks!
Aug 21, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a coleman emerald 455 hot tub and I have managed to lock the electronic control panel. How do I unlock?
press program and then mode, it will display "0" and will be unlocked. u locked it by pressing program twice
Nov 05, 2010 | Pool & Spa
I need an owners manual for a Coleman Spa Horizon series 447
Chuck, did you find the manual? If not I have one with my spa maybe I could copy it for you.
Ron
Sep 04, 2009 | Coleman Sport & Outdoor - Others
Need owners manual for coleman spa 208 or 408
Go here and print it out. Nancy
team.maaxspas.com/manuals/horizon%20series%202000.pdf
Dec 19, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
